DSM injectors with turbo civic
Old Jul 10, 2002 | 09:32 PM
qtiger's Avatar
qtiger
Originally posted by CazanCivic
What size injectors come stock with my civic?
Uh... 240cc.
Old Jul 10, 2002 | 09:50 PM
OneToughCivic's Avatar
OneToughCivic
http://members.aol.com/Inspyral/mycar.html
whatever happened to inspyzee fa sheezy?
Old Jul 10, 2002 | 10:09 PM
Bakeoff's Avatar
Bakeoff
wooooo woooooooooo
so what is plug and play? obd1 civics, dsm injectors bolt right up? no mods to the fuel rail?and can you back off the mixure just running an adjustable fpr???
Old Jul 10, 2002 | 10:13 PM
Smurf's Avatar
Smurf
Dancing Banana Driver
Look at his engine mods at this link:
Inspyral :naughty:
Old Jul 11, 2002 | 06:29 PM
ManTiS's Avatar
ManTiS
NinJA
It's a pretty tight fit into the IM. I bored out the lower seals. You could also go to Home Depot or something and get faucet washers (5/8" i.d., i think...). I lost one and had to improvise.
It's a b1tch, but for $50 ... can't beat it. Yes, OBD2 clips do not fit. Just go to the auto store or something and buy some. I got all (4) clips for $25. Resistor box cost me $30.
P.S. Oh, make sure the fuel rail is bolted on nicely because an injector popping out is NOT good.
Old Jul 11, 2002 | 06:31 PM
CazanCivic's Avatar
CazanCivic
Where did you get the resitor box?
Old Jul 11, 2002 | 06:42 PM
ManTiS's Avatar
ManTiS
NinJA
eBay
Old Jul 14, 2002 | 05:04 PM
inspyral's Avatar
inspyral
のんびり~(´ε`)
Default Re: DSM injectors with turbo civic
I have heard people running stock DSM 450cc injectrs with thier turbo setups on civics. Anyone got any more info on this? Do they fit, or is modification needed to make then fit? Also would I be running to rich with 450cc injectors@ 7psi with the GReddy kit, FMU, intank fuel pump, missing link, and FPR?
Mine fit right in, I didn't bore out the lower seals or anything, I just put them into the rail and bolted the rail down tight and they popped tight into the manifold with a little help. I got my resistor box for $1(yah, a dollar) off eBay, and the injector clips for $10 from dsmtrader.com. Install was straightforward - yanked out my FMU, Missing Link, and inline pump; soldered all the connections; swapped the injectors; and set the fuel pressure and AFC settings. Fuel pressure is ~24/34 vac/atmospheric, and fuel trim on the AFC is set at -40% across the board. With an unlimited MAP, this setup is good up to about 8-9lbs of boost. If you go over that, you'll need some way to limit your MAP signal as to not throw a code. If you're going to run this setup, you won't need an FMU, since they're only needed when running smaller injectors(like stock). You also won't need the Missing Link unless you plan on boosting more than 8-9lbs. Yes, you need an AFC or standalone ECM in order to control injector pulse. One of the benefits of running an unlimited MAP is that you can use the pressure display on the AFC as a secondary boost gauge
If you need your injectors cleaned and flow-tested, this place has some excellent prices:
http://www.cruzinperformance.com/fuelinj.html
Flow Test Only, no disassembly or cleaning...............$5.50 per injector.
Complete Flow Test and Cleaning.............................$11.00 per injector.
Making up exact matched sets (when available)...add $5.50 per exchanged injector
Old Jul 14, 2002 | 07:16 PM
CazanCivic's Avatar
CazanCivic
I ended up getting RC 310cc injectors instead. Right now my plans are Walbro 255 intank fp, 310cc injectors, S-AFC, missing link, running 7psi with the GReddy kit w/ stock internals. Thanks for the info.
2000IntegraLS
Dec 1, 2004 08:26 PM
xtreme
Jan 16, 2004 07:14 PM
combustion gsr
7
Sep 21, 2003 06:29 PM
layz1
Nov 9, 2002 11:38 AM
