Interior dome light
Old Jun 20, 2003 | 04:52 AM
civicburner's Avatar
civicburner
Default Interior dome light
My interior dome light does not work when I open my door. It works when i turn it on manually though. The interior light fuse isn't burned out. Does anyone have any idea why it doesn't work?
Old Jun 20, 2003 | 05:35 AM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
Does it work when you open any of the other doors?
I ask that cause if it does, then it could just be the switch on your driver door. h:
Old Jun 20, 2003 | 05:57 AM
Dubs's Avatar
Dubs
Just wait...
Make sure the switch is in the center...
Old Jun 20, 2003 | 06:05 AM
str8edgexx's Avatar
str8edgexx
Let me guess....you changed your factory deck for an aftermarket stereo, and now the dome light only works when you manually turn it on and off
Old Jun 20, 2003 | 06:15 AM
westcoaststyle
I thought it might be something like that... how does it happen?
Old Jun 20, 2003 | 06:40 AM
96GreenCivic's Avatar
96GreenCivic
Ok I think I know the problem. I had the same when I changed my head unit. Believe it or not, the dome light was run through the factory head unit. You have to cut and crimp two wires together to get them to work. I'll call crutchfield and find out which wires again.
Old Jun 20, 2003 | 06:41 AM
HatchVX's Avatar
HatchVX
Driving a Turbo 2L Terror
Its in the radio harness, I did a system for one of my freind in her 99 civic and her light work. We used a Walmart wiring harness. Try that. I have heard that it was to do with keyless entry. but im not sure.
Old Jun 20, 2003 | 06:54 AM
96GreenCivic
Ok, I think you have the same year as mine so you should have keyless entry. Just got off the phone with Crutchfield. Pull out the HU and on the Factory part of the harness, look for the green/red wire and green/black wire. Then cut them and crimp them together. That should solve your problem! Let me know if it works.
Old Jun 20, 2003 | 08:12 AM
Mandi's Avatar
Mandi
isnt that the biggest POS idea that HONDA came up with for the 96-98 civics??? i have no keyless entry and no dome light...thats great for a 19 year old female....glad i dont park in dark parking lots or anything.. h:
anyone know how to fix it?? the part of the harness is mounted on the back of the old head unit...so what do we do?? i REALLLY want my keyless entry back!!
Old Jun 20, 2003 | 08:13 AM
Mandi's Avatar
Mandi
is that just for the dome light??
i lost the keyless entry in my 97...
