Distributor Rotor
Old Jun 14, 2003 | 11:09 AM
maestro5050's Avatar
maestro5050
Default Distributor Rotor
I replaced my distributor rotor, distributor cap, and plugs last week. Since then I have had a problem with my stereo. (See this post)
I did not know that the 96 Civic came with two different distributors, not physically two in the car, but two different types were used in the same year model. I guessed which cap and rotor I needed. The cap was easy to guess since only one of the two had the right bolt pattern. The rotor I guessed on.
Now my question is, obviously different rotors are used on the different distributors, but would one fit the other and vice versa? I just want to make sure I got the right one.
Thanks guys.
Old Jun 15, 2003 | 07:40 AM
maestro5050
Bumping in hopes of finding an answer.
Old Jun 15, 2003 | 12:41 PM
94civicEX's Avatar
94civicEX
I got worms.
Hmm...that's odd, I'd think if your car was running fine that your stereo would still work. You didn't disconnect it from the battery or anything did you?
99 Integra GSR
06 TSX
duck squad member #00003
Old Jun 15, 2003 | 04:26 PM
maestro5050
I disconnected the battery ground wire while installing the new stuff. But it was put back nice and secure afterwards. There's no corrosion or nothing on it.
Anyone got an answer on the rotors?
Old Jun 15, 2003 | 04:54 PM
AP1dude's Avatar
AP1dude
JDM WHORE!!!
rotors wouldn't affect it........maby your alternator or you might need a compacitor(correct me if spelled wrong).
Old Jun 15, 2003 | 05:17 PM
NeverBX's Avatar
NeverBX
Snootchie Bootchies!!
well if your rotor is causing any RFI then you will need some silicone grease. apply the silicone grease on the inside bottom of your spark plug wire boots, just a thin layer. it helps to cancel out RFI most of the time. but to me it just sounds like a bad ground somewhere in the system.
