Tires on SI wheels
Old Jul 5, 2002 | 06:08 PM
ManInCamo's Avatar
ManInCamo
Old School Crew
Originally posted by VTEC
Bridgestone RE730 or S-03. The RE730 was the best 300UTGQ tire I've ever driven on...
The difference between the Bridgestone and others like Khumos is definitly noticable
205/50/15
You got em all for $350? not a bad price, not a bad price at all. Where did you buy them at?
Old Jul 5, 2002 | 07:00 PM
FourthGenHatch's Avatar
FourthGenHatch
I'm RICK JAMES, bitch!
I have 205/50R15 Kumho ECSTA Supra 712's on my car and they are excellent! They stick like a dream, they absorb a lot of vibrations from the road and ride very smooth, and are an overall good tire for the price.
Old Jul 5, 2002 | 07:03 PM
FourthGenHatch
Also my friend has Michelin Pilot Sports or something like that and they are rated almost a perfect 10 in everything by many many places but they are expensive, almost $150 a tire.
Old Jul 6, 2002 | 09:42 AM
CivicRicer's Avatar
CivicRicer
I'm rollin' on 195/50's on my car with Si rims. What should the tire pressure be set to? 30-35lbs?
Old Jul 6, 2002 | 09:45 PM
undercover's Avatar
undercover
Got em at Tirerack.com, $81 a tire for 195/50/15.
Old Jul 7, 2002 | 04:18 AM
FourthGenHatch
35psi should be right. But try experimenting to find one you like. I'm running 35 now but I think I'm gonna try out 38 soon.
Old Jul 7, 2002 | 04:31 AM
noEqual's Avatar
noEqual
I thought that they took almost 50psi? Is 35 your recommended? I'll have to double check!
Old Jul 7, 2002 | 08:11 PM
SiClone's Avatar
SiClone
X-Moder8er
50 psi is the max tire pressure, NOT what you should run it at. Look at the sticker inside your door sill. For Si's and GSR's, fronts should be 35 psi and rears should be 33 psi.
Old Jul 8, 2002 | 12:50 AM
noEqual's Avatar
noEqual
thanks a lot...!!! Dude, I was running the PSi that high. No wonder it was such a harsh ride.
Old Jul 8, 2002 | 06:20 AM
PatrickGSR94's Avatar
PatrickGSR94
I'm not a n00b!
Running 38-40 or higher all the time can wear out the center of the tire tread way too early (I did this on my old car w/ 205/50-16 Nittos).
I have Nankang EX-500 205/50-15 V-rated tires w/ 320 treadwear. After 25K+ miles total, 10K of that being lowered w/ 2.3 deg. neg camber in front, they still look like this:
