rim????????
Old May 19, 2003 | 01:37 PM
davetec's Avatar
davetec
Default rim????????
this might be a little of a strange question but i have 16 inch rims on my civic if i put 18's on it will it make it slower and will 18's even fit somone told me they would make it slower thats y im asking
Old May 19, 2003 | 03:21 PM
txhatch's Avatar
txhatch
I hate 2003 Noobs.
Yes and gayer.
Old May 19, 2003 | 04:56 PM
crxb16er's Avatar
crxb16er
yah a bigger diameter wheel size makes it harder to turn over the wheel which makes it slower, smaller wheel diameter makes closer gear ratios but at the same time may make it to where ur car can't break 100 mph, smaller wheel size is easier to turn, requires less torque, just think of it in the terms of physics, its harder to turn something with a bigger circumfrance because the wheel is travelling a bigger difference
Old May 30, 2003 | 11:26 PM
forum95's Avatar
forum95
I'm Cooler than You
Get SSR competition's one of the lightest 18" wheels in the world
Old May 31, 2003 | 05:33 AM
davetec's Avatar
davetec
i font some in one of my friends mag. and they said all of the rims together is about 40 pounds so im thinking about those
Old May 31, 2003 | 06:24 AM
crxb16er's Avatar
crxb16er
you want something light regardless but a bigger wheel diameter means its harder for your engine to turn the tire which means ur car will go slower, plus lower profile tires wear out quicker than say 215/40/r15 or 16s
Old May 31, 2003 | 11:52 AM
MrFatbooty's Avatar
MrFatbooty
Wannabe yuppie
This doesn't really have to do with Engine Tech. Moving to Civic 1992+.
Old May 31, 2003 | 05:43 PM
randomtask77's Avatar
randomtask77
Wanderer
They will fit, but most likely you'll experience some rubbing either when you turn the wheels or when you hit bumps and potholes.
Aesthetically, they only look decent when complemented with a body kit and the sorts. 18's on its own looks pretty ridiculous.
Yes, it would slow down the car, if not by the weight of the wheels, then just by the sheer fact that it's harder to turn a bigger wheel than it is compared to a smaller diameter wheel.
If for some strange reason you still feel the need to get a set of 18's, make sure that you get a 18x7.5" wheel with at least a +42mm offset. Mate that with 215/35/18 tires.
Old May 31, 2003 | 10:07 PM
maestro5050's Avatar
maestro5050
Personally I wouldn't go with anything bigger than 17 inches. If you are looking for speed, go 15" or maybe 16". Personally I have 17" on my car. I can tell you from experience that you will probably want no wider than 7". With my drop kit my 17x7 wheels don't rub. On the other hand, the 17x7.5 rims I put on there to test fittings rubbed like a SOB.
