info on brake swap 92-95 sedan
Originally posted by randomtask77
This is why I grew fond of this board. Members helping members. Good info there doood. :thumbup: Have you thought of switching your brake lines to steel braided?
Yes, Im using Earl SS lines
Originally posted by toadolson
Since we are on brake's, i just did a gsr disc on the rear. (94 DX Coupe). Doing a B18C1 later with a disc convertion on the front. What's the main benefit for changing the MC. Did not think of this during the whole change. Higher psi or ??
Pedal travel greatly reduced allready. On order, steel lines, aem pads, slotted disc.
The MC will help in the amount of fluid pressure moved to the bigger brakes. Since you are putting in bigger brakes, it is recommended that you get a bigger MC to accomodate them.
Originally posted by asiandoood
For bottom fo the line trim (CX, VX, DX, LX) the cars do not come with rear disc brakes. Doing an Integra brake swap which bolts on to the EG Civic upgrades you to rear discs, and bigger rotors and calipers. Doing so cuts down the braking distance dramatically especially when you plan or have a bigger and faster motor in the car.
just some info
Originally posted by wxt
my friend also did a gsr swap and when we compared civic EX calipers and rotors they were the same size as the GSR's
just some info
just some info
To the best of my knowledge, the calipers and rotors are the same size. The GSR pistons are bigger.
i sure hope you are putting in polyurethane bushings since you are doing all this work!
anyways. would a 92 si have a 40/40 proportionate valve? i've got stock rear disc brakes and i picked up a 1" gsr mc/booster for $35 a while back so I'm gonna be reflaring/bending my lines.
i always planned to just use my stock proportionate valve.
Anyone elaborate for me?
yes...I believe the Si has the 40/40. You can double check yourself by looking at the valve yourself. It should be stamped 4040 on the side.
