info on brake swap 92-95 sedan
Old Apr 5, 2003 | 09:16 AM
Nelson's Avatar
Nelson
Administrator
That's really good info doood. I just need to upgrade the rear to disc's at least. For the front, I am doing a different swap, possibly. Definitely need to search for the e-brake cable and MC. Did you say 4th gen?
9Y0 Cayenne GTS
E46 ///M3
YD4 MDX
- SOLD
EG Ferio - SOLD
FA Ferio - Returned
www.NelsonLee.net
Old Apr 5, 2003 | 09:24 AM
asiandoood's Avatar
asiandoood
sancho on the sizzide!
Curious...which fronts are u going to use?
My research tells me that the 1991 Civic EX sedan has the 15/16 MC that bolts onto the stock booster of our DX/LX. Im probably going that route for my setup.
The RS Integra MC also bolts up but you need the matching booster.
Also, if you want to, get a 40/40 prop valve from a 93-95 Si hatchback or a 90-93 Integra. I got my 40/40 off a 91 Integra. Bolts right up. I've heard its recommended...but not required.
The GSR/ITR MC is nice...but will probably be overkill on my current setup. If I dont find the parts I need...I'll probably go with the ITR and try to rebend/reflare lines myself h:
Old Apr 5, 2003 | 09:30 AM
dnt94civic's Avatar
dnt94civic
Just for a little bit of clarification:
From my personal experience,
If you get a GSR MC/booster, you will need to re-bend both brake lines, AND reflare one of the brake lines.
If you get a ITR MC/Booster, you will only need to re-bend the brake lines. You DO NOT need to reflare the lines.
Old Apr 5, 2003 | 09:34 AM
asiandoood's Avatar
asiandoood
:thumbup:
I knew I got it mixed up somewhere h:
Old Apr 5, 2003 | 09:42 AM
agent87's Avatar
agent87
Need zzzzz's
Sorry, I know I asked you this before at one time, but how did you bend the lines? Did you use a tool or do it by hand?
Old Apr 5, 2003 | 10:39 AM
Sasebonian's Avatar
Sasebonian
'Till All R one!!
Yeah I kind of ran into the same problem. I used del sol rear disc brakes for my upgrade. I ended up getting the lines from a 92-95 civic sedan that had the brake lines I needed. I did it in parts, so the next day I went and got the correct MC. It made a big difference on the distance I had to press on the brake pedal. For me, I think I needed the PV from an integra RS which is supposed to fit right in without any bending.
Old Apr 5, 2003 | 11:15 AM
94civicEX's Avatar
94civicEX
I got worms.
Good info Colin. You're doing a how-to right :squint:?
I still wish I knew why my EX didn't come with all wheel disc brakes, yet I have ABS :dunno:.
If I keep my car, I plan on doing this sometime in the future, so this is awesome information, thanks DiEW!
99 Integra GSR
06 TSX
duck squad member #00003
Old Apr 5, 2003 | 11:59 AM
randomtask77's Avatar
randomtask77
Wanderer
This is why I grew fond of this board. Members helping members. Good info there doood. :thumbup: Have you thought of switching your brake lines to steel braided?
Old Apr 5, 2003 | 05:24 PM
Nelson's Avatar
Nelson
Administrator
:huh:
I'll PM you on that :a:
9Y0 Cayenne GTS
E46 ///M3
YD4 MDX
- SOLD
EG Ferio - SOLD
FA Ferio - Returned
www.NelsonLee.net
Old Apr 5, 2003 | 05:38 PM
toadolson's Avatar
toadolson
The One And Only!!!
Since we are on brake's, i just did a gsr disc on the rear. (94 DX Coupe). Doing a B18C1 later with a disc convertion on the front. What's the main benefit for changing the MC. Did not think of this during the whole change. Higher psi or ??
Pedal travel greatly reduced allready. On order, steel lines, aem pads, slotted disc.
