projector light and indiglo light installation
I've seen people post about 9005 silverstar conversions... and you guys say h3 suck balls when it comes to light output. any methods to headlight conversions??? higher output is what i'm interseted in
Use the harnesses, theyre fused inline to keep for burning anything up. Besides they have relays also that let you use high/low beams both at the same time.
As far as light output theyre a little dissapointing. I modified my projectors and took out the shields in the low beams. Light output jumped over 100%, no problems so far, they just constantly look like high beams even after alignment and adjustment.
Originally posted by asiandoood
make sure it lines up right, or you'll have huge gaps between the lights and bumper.
Originally posted by derf
hmmm arch didn't say anything about the crossmemeber.. well whatever I take off, it will go back on the car...
There really is no way to convert to 9005 bulbs, because the way the bulb mounts in the housing is completely different, and the projector housing itself is smaller diameter than those used in Integras.
