projector light and indiglo light installation
Old Jun 26, 2002 | 09:06 AM
PatrickGSR94's Avatar
PatrickGSR94
I'm not a n00b!
Originally posted by derf
how are the high beams?
Well they use H3 also I believe, so I guess they would be like H3 driving lights. Why does it matter, though, you hardly ever use high beams.
Old Jun 26, 2002 | 10:35 AM
asiandoood's Avatar
asiandoood
sancho on the sizzide!
as far as i know from my previous two sets
H3 low beam
H1 high beam
basically the same bulb....but different light projection. low beams are projectors and high beams are reflected
Old Jun 26, 2002 | 10:42 AM
derf's Avatar
derf
Spec5
the way I c it.. if you say h1 output sucks, well i might be using the highs more... to compensate... ya know
Old Jun 26, 2002 | 11:16 AM
asiandoood's Avatar
asiandoood
they are both the same...just projected differently.
..running just the inners (high beams) look awkward.
Old Jun 26, 2002 | 11:24 AM
crucial Si's Avatar
crucial Si
Banned
yeah the h1s do suck but for me i like it better than stock lights. just dont forget to run the wire harness that came with the lights or you will short something out and cause a fire.
Old Jun 26, 2002 | 11:59 AM
derf's Avatar
derf
Spec5
of course I would use the harness that came with the lights.... how else could you hoook up them up?
Old Jun 26, 2002 | 12:59 PM
asiandoood's Avatar
asiandoood
plug and play...u dont need the harness
Old Jun 26, 2002 | 01:36 PM
derf's Avatar
derf
Spec5
how is that so? the regular harness is one connector you need two for projectors...?!?
Old Jun 26, 2002 | 02:00 PM
asiandoood's Avatar
asiandoood
unplug your stock lights...the connector should be a 2 prong plug... plug that into your projectors.
harness is only used if you want to run both hi and low beam at the same time.
Old Jun 26, 2002 | 04:10 PM
crucial Si's Avatar
crucial Si
Banned
i dont recommend you doing it without the harness you could burn something up really quickly
