Head Unit Problems
Old Mar 10, 2003 | 04:24 PM
The Beav's Avatar
The Beav
i
Default Head Unit Problems
2 Problems Here
First my keyless entry is acting up, and it's connected to the stock head unit, i have an aftermarket unit, but the stock one is still mounted behind for the keyless, now my keyless entry doesn't work and i need to be able to get back to it.
First - i can't seem to get the panel out to get to the area behind my head unit and i removed the two screws, but i can't get past that part
Second - i need to now how to reset the remote and headunit to synchronize up the keyless entry
thanx, sorry it's long and yes i looked in the haynes manual first
Old Mar 10, 2003 | 05:11 PM
Hondaman's Avatar
Hondaman
Black Pearl
Most likely the old head unit is behind the cig lighter. It probably came unhooked from bouncing around in there. What year civic is it?
Old Mar 10, 2003 | 06:00 PM
The Beav's Avatar
The Beav
i
it's still mounted good i can see it, and there is still power to it, i have a 96 ex coupe
Old Mar 10, 2003 | 06:36 PM
Hondaman's Avatar
Hondaman
Black Pearl
:dunno:
Old Mar 11, 2003 | 06:30 PM
The Beav's Avatar
The Beav
i
come on, somebody has to know
Old Mar 11, 2003 | 06:35 PM
XScarAudio's Avatar
XScarAudio
///o\\\///o\\\
lmao....havent had to deal with this problem in a looong time. has it worked, and it stopped or what?
Old Mar 11, 2003 | 06:53 PM
The Beav's Avatar
The Beav
i
yeah the keyless worked for a while, they just stopped one day, i'm just now gettin around to tryin to fix it
Old Mar 11, 2003 | 06:56 PM
XScarAudio's Avatar
XScarAudio
///o\\\///o\\\
first, check the fuse for it. i dont remember if that one is in the car or under the hood. if not, make sure one of the wires in the split harness didnt come loose. third, there is a "reset" button on the front of the stock head unit between a couple of the buttons on it. i dont remeber how to reprogram, but just call your honda dealer and ask their service dept. explain the situation and they're probably gonna tell you how to reset/reprogram the circuit. could be a bump made your stock reciever think that you were trying to steal it, and now it doesnt function, and you have to enter the code for it.
Old Mar 11, 2003 | 07:08 PM
The Beav's Avatar
The Beav
i
ok that's cool, but first i need some help gettin the panel out, i removed the two retaining screws on the bottom and i can't figure out what else i need to do
thanx for your help
Old Mar 11, 2003 | 07:10 PM
XScarAudio's Avatar
XScarAudio
///o\\\///o\\\
ummm
screws *thinking back* gotta remove all 3 pieces of the center console.(start w/ the screws at the back, and work forward....6 screws total i think, then each piece lifts out) then the front part lifts up. i'll look in the morning
