HELP!! code 54!! CKF sensor???
Old Feb 27, 2003 | 02:10 PM
stehigs321's Avatar
stehigs321
Default HELP!! code 54!! CKF sensor???
Help me guys i got a code 54 thrown. I have a 99 gsr motor in my 96 civic ex. I have no idea what to do. Please help a brother out.
Old Feb 27, 2003 | 02:58 PM
txhatch's Avatar
txhatch
I hate 2003 Noobs.
The CKF sensor may need to be replaced. It shouldnt hurt the performance of the car.
Old Feb 27, 2003 | 03:12 PM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
Originally posted by txhatch
The sensor may need to be replaced.
Ouch, that's a bad code to have cause you have to basically perform the hardest part of a timing belt change just to get to the sensor. Sorry for you.
I'd see if you could get another sensor from someone that you know for sure works and try it. If you still throw the code, you have a mechanical problem with the engine or that sensor may not be connected to the ECU correctly.
Sucks to be you right now. :happysad:
Old Feb 27, 2003 | 09:43 PM
madtownhonda's Avatar
madtownhonda
I'm guessing that you never wired it up when you did the swap. The CKF plugs are different from D to B series. You need to match up the plugs; I used a D series plug on the engine and plugged it into the harness. You can use a B plug on the harness though if you want.
Old Feb 27, 2003 | 09:46 PM
SUPER LAUBO's Avatar
SUPER LAUBO
KiMBO's Hubby
exactly, i ended up splicing and soldering the B series plug onto the D series harness. works like a charm :thumbup:
Old Jun 4, 2003 | 07:56 AM
Civic Type Sev's Avatar
Civic Type Sev
Hello guys... I'm having the same problem with my swap. I've installed the B16A2 from a Del sol into my 97 Civic DX. Where on the engine can I find the connector for this sensor?? Maybe some pics? Where is this sensor on the engine? I would really appreciate the help.
