tranny problem?!?!
i doubt the throw out bearing has anything to do with it.
did you remove the shift linkage that attaches to the tranny, by a ping? or did you leave that one on? i usually leave that shift linkage attached cause that pin is hard to get out with limited space.
i'd double check the shift linkage.
Originally posted by upgraded Si
we popped the pin out.....and hammered it back in....
I don't know if that would mess up the linkage enough to cause the gear to pop out....
Originally posted by DelSolSIinMD
I know you're only supposed to use a new pin... not sure if you did this, but using the old pin causes problems. Everything manual I've seen has explicitly said "After removing the pin, throw it away; use only a new one."
and it is still popping out, could this be do to my ss?
please help, i dont want my second gear syncro getting fawked up like my third gear...thanks...
