i have come to the conclusion that.....
Old Jan 31, 2003 | 03:07 PM
ryewdedyet's Avatar
ryewdedyet
Most ODB2 cars will not start if the ECT (engine coolant temp) is not connected or if its faulty. Check to see if there is voltage. Another thing that may cause a no start is an unhooked MAP (manifold absolute press) sensor. If these two items are properly connected then you might want to check to see if the car has spark. Use a long screwdriver and probe it in one of the spark plug wires and bring it close to the chassis about 1/4 of an inch away. If there is spark then you'll see a spark leap from the screwdriver onto the chassis of the car. (Be sure you don't get shocked).
Another thing that may cause a no start but the car cranks is a defective coil or igniter. For checking the coil you can use a simple test light with two wire leads on it. One of the leads you connect to a good ground. The other onto the positive side of the coil. As for the tip of the test light, touch it to the negitive side of the coil. (You'll need to remove the cap to do this test). The have somebody help you crank the engine. If the bulb on the test light lights up then the igniter is working properly. You can then make a conclusion that the coil is bad. But if the bulb on the test light does not light up then you have a bad igniter. You also would want to check the ignitier to see if its getting a signal from the ECM. If the igniter doesn't get a signal from the ECM then you have a bad ECM.
If there is spark coming from the spark plug wire, a spark from the coil, and signal from the ECM onto the igniter, then you would want to check to see if you have fuel. The easilies way to diagnose this is by removing the gas cap and have somebody turn the key to #2 (key on engine off - KOEO). You should hear a quick hiss from the fuel pump sucking in fuel. If you don't hear a hiss then re-do the test over again several times. By doing this test, you are trying to determine to see if the main relay is bad. If for some reason you do hear a hiss but it's not consistant then you're main relay is faulty. If you do not hear any hiss after performing this KOEO then there is a good chance your main relay is faulty.
There are other tests you can do. Hope this helps.
Old Jan 31, 2003 | 03:15 PM
19.3secS2K's Avatar
19.3secS2K
my bum is on the swedish!
isn't his an OBD1?
Old Jan 31, 2003 | 03:21 PM
crucial Si's Avatar
crucial Si
Banned
Originally posted by 18secFerio
isn't his an OBD1?
sure is.
Old Jan 31, 2003 | 03:22 PM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
Originally posted by upgraded Si
sure is.
Old Jan 31, 2003 | 05:08 PM
CivicSiRacer's Avatar
CivicSiRacer
Honorary Moderator Alumni
Did you even try a new battery? If the car is clicking but not cranking over than it could be the battery. If the car is turning over but not starting could be the starter or the wires are plugged in the wrong order.
Autocross Help Page
Old Jan 31, 2003 | 05:16 PM
19.3secS2K's Avatar
19.3secS2K
how about the solinoid?
Old Jan 31, 2003 | 05:21 PM
ManTiS's Avatar
ManTiS
NinJA
A vehicle is only as good as it's user. Please don't blame the car because you can't get it to work. People like you should take it to Sears.
Old Jan 31, 2003 | 05:56 PM
westcoaststyle
Default Re: i have come to the conclusion that.....
Originally posted by civic924dr
it cranks but wont start.
He said it cranks so it shouldn't be the starter or the battery....
I still say he changed something and that's the problem.
Old Jan 31, 2003 | 05:57 PM
westcoaststyle
Sounds like an iD10t error to me.. :chuckles:
Check www.jdmfan.com for that on the CEL listing... :rofl:
Old Jan 31, 2003 | 09:32 PM
tokyoracer's Avatar
tokyoracer
got JDM milk???
civics are junk. so far, i have changed the dist cap, rotor button, ignition coil, pickups in the dist., plugs and wires, and lower half of the dist. well, now the damn car wont even start. before it would die while at a stop light. 2 nights ago it ran perfect. now we get up this morning and it wont even start. it cranks but wont start. wtf else is there to look at? i hate this ****ing car..btw: its a 92 dx 4dr auto
dude... check and replace ur starter. my friend's CRX did that and that was the problem. also... u might want to replace ur fuel filter and get some duralube injector cleaner.
