Painting my trim!
Old Jan 27, 2003 | 06:52 PM
flappy188's Avatar
flappy188
O.G. SON!
Originally posted by upgraded Si
aight cool, you should only use a quart, runs for about $20 for ppg paint. with clear use about the same thing b/c with a quart of clear, and you mix it 1/1 or even 1/2 with the hardener depending on which brand you go with, the clear should have a kit, ie, clear, hardener, and reducer.
wetsand everything down first with a light grit paper and just skuff it up a bit so the paint will stick, and what i said about if you mess up, it doesnt apply here since you are doing it with a spray gun.
thanks!!!!! is there any other pointers u might want to give?
i thought u were supposted to lay the paint first and then clear over that!?!?!?!?
Old Jan 27, 2003 | 06:54 PM
crucial Si's Avatar
crucial Si
Banned
just make sure after you wetsand, make sure they are clean, get some pre-cleaner at the paint store also. and rub them on the parts RIGHT b4 you start to paint. i would suggest you use nothing rougher than an 800 grit. just scuff the parts up a bit.
wait about 15min after each coat to continue, if not longer.
dont use toooo much hardener, it will turn the clear yellow.
Old Jan 27, 2003 | 06:56 PM
flappy188's Avatar
flappy188
O.G. SON!
offtopic but you got anything u wanna sell from the hatchie??????? vision corners???? thanks!!!!!!:thumbup: :thumbup:
Old Jan 27, 2003 | 07:04 PM
crucial Si's Avatar
crucial Si
Banned
im not parting out anything yet, until its time to sell the car.
Old Jan 27, 2003 | 08:54 PM
flappy188's Avatar
flappy188
O.G. SON!
damn u!!!!!:fawk: :fawk: :thumbup:
Old Jan 27, 2003 | 09:48 PM
randomtask77's Avatar
randomtask77
Wanderer
I'd suggest taking off the mirrors and the side valence rather than masking around them. It's so much easier that way.
Old Jan 28, 2003 | 04:39 AM
94AccordSedanEX's Avatar
94AccordSedanEX
Make sure to take before & after pics! Good luck!
Old Jan 28, 2003 | 07:08 AM
flappy188's Avatar
flappy188
O.G. SON!
is there mixing directions on the cans cause i think we are gonna fawk this shit up?
Old Jan 28, 2003 | 12:43 PM
crucial Si's Avatar
crucial Si
Banned
yes there are special mixing directions, talk to your local paint shop.
Old Jan 28, 2003 | 02:27 PM
The Bum's Avatar
The Bum
Black people go wooooo
Definately get more info from your local shop.
What color is your car? If its silver, your gunna have a hell of a time matching perfectly.
I recommend painting your skirts and mirrors a color thats on the opposite end of the spectrum than the color of your car. IE, BRIGHT YELLOW!!! That would be siiiiiiiiiiiiiccccccccccckkkkkkkkk.
Ok, im done...
