lugnut torque
Old Jan 25, 2003 | 10:30 AM
00-00-00's Avatar
00-00-00
E M I N E M
Default lugnut torque
how much torque for putting on your wheels on a 98 honda civic?
Old Jan 25, 2003 | 11:44 AM
CivicSiRacer's Avatar
CivicSiRacer
Honorary Moderator Alumni
80 ft/lbs. Make sure you use a torque wrench.
Autocross Help Page
Old Jan 25, 2003 | 12:18 PM
crucial Si's Avatar
crucial Si
Banned
i did mine to 78ft/lbs, and now, the lugs are on there TOOOOO fawking tight, i had to get a braker bar to loosen them up, BUT some of the lugs stripped.
Old Jan 25, 2003 | 01:07 PM
boosted98's Avatar
boosted98
Default torque spec
yea the spec is 80 ft pounds with a 19mm torque stick.
Old Jan 25, 2003 | 04:32 PM
00-00-00's Avatar
00-00-00
E M I N E M
ok thanks all.. i have a torque wrench, just needed spec
Old Jan 25, 2003 | 04:40 PM
Apocalyps's Avatar
Apocalyps
Put it on just tight enough so that you can remove them with your car accessories in case you get a flat. Specifications are always tighter than necessary.
Old Jan 25, 2003 | 05:49 PM
agent87's Avatar
agent87
Need zzzzz's
Could it be possible that they seemed like they were on so tight because they were cross-threaded? Using a breaker bar isn't out of the ordinary at 80 ft-lbs. I slip a small pipe on my ratchet when i loosen my lugnuts.
I'd be careful though. If you make them too loose, they might not stay tight over time.
Old Jan 25, 2003 | 06:02 PM
Bumnah's Avatar
Bumnah
So OG it hurts.
the torque amount is use is. "real ****in' tight"
Project EVA - The Track Package
Project EVA
Old Jan 25, 2003 | 06:04 PM
agent87's Avatar
agent87
Need zzzzz's
PING! "aw crap...how do I get the rest of the bolt/stud out?"
Old Jan 25, 2003 | 06:10 PM
Bumnah's Avatar
Bumnah
So OG it hurts.
I enjoy living on the edge.
Project EVA
