lugnut torque
Well you should use antiseize compound on the threads.
Autocross Help Page
Autocross Help Page
Originally posted by boosted98
yea the spec is 80 ft pounds with a 19mm torque stick.
Originally posted by smudge
It's always good to re-check them after a day or two.Mine came a tiny bit loose after a cpl of days(better safe then sorry
Autocross Help Page
Autocross Help Page
Originally posted by rick
if you use antiseize on the threads then you need to reduce the torque value by aproximately 10-15%
Ever since I started using antiseize no more threads locking together.
Autocross Help Page
Autocross Help Page
cx power!
ehh... ive only broken one stud in my lifetims (and ive removed dozens of sets of wheels). it was seized b/c my brake had cracked and was draggin on the rotor, causing it to over heat the hub
Originally posted by CivicSiRacer
No it makes engagement of the threads smoother. After breaking 3 studs this year. Once using a cordless drill, and twice by putting the lugs on by hand then torqueing them down - I asked the my autocross club what they do to prevent it and they said anti-seize compound. THe lugs are aluminum and the threads are steel/aluminum. When you get grit, water, and salt in there it seizes.
Originally posted by agent87
Hmm... Out of curiosity, are you running hubcentric rings with your autox rims?
Autocross Help Page
Autocross Help Page
just relaying what I was told by several seasoned track drivers/mechanics.
it makes the engagement smoother by reducing friction.
friction is what makes the lug nuts tighter. less friction means you can tighten the nuts easier.
that's how it was explained to me. but we hardly get salt on the roads here in CA
I only use anti-seize on the hub and rotor to prevent it from fusing together because of rust.
'00 Dakar Bus CRS Edition
LCD Squad #0001
LCD Squad #0001
Autocross Help Page
Autocross Help Page
