brake pedal problem
Old Jun 26, 2003 | 07:06 AM
Andy's Avatar
Andy
Hybrid Forum Moderator
I think it's that similar threads thing at the bottom, links to old threads. Sounds me like the MC is failing. It's not something a garage can really check as you can't see inside of it. If the seals are failing, I can't efficently push fluid and it won't work. Do the cheap thing first, bleed the hell out of it and make sure there is no air, but it may need a new MC.
Old Jun 26, 2003 | 06:20 PM
boblite44's Avatar
boblite44
Originally posted by CivicSiRacer
HOw the hell do you read through 5 months of posts? You must be bored as hell!
Did'nt read 5 months of posts. Found this thread thru searching "Honda brake problem" on Google.
Old Jun 26, 2003 | 06:26 PM
boblite44's Avatar
boblite44
Thanks, Andy. WIll follow up on your suggestions. Regards. Bob
Old Jun 26, 2003 | 06:37 PM
agent87's Avatar
agent87
Need zzzzz's
I completely agree and had the same thing happen in my integra.
BTW, I think the similar threads feature rocks.
Old Jun 26, 2003 | 07:52 PM
Andy's Avatar
Andy
Hope that fixes it. I'm also not sure if this is true or not, but I've heard the check valve that goes between the intake manifold and brake booster (to provide vaccum for the booster) can also start to fail/wear. You might even want to try changing that fitting and line (small hall could cause the same effect), could save you having to change the MC. Seeya.
Old Jun 27, 2003 | 07:55 PM
boblite44's Avatar
boblite44
Thanks Andy but too late. Had it bled again by my garage but this did not work. Had MC replaced today and have had no recurrence of brake problem yet. But if I do, I'll show them your post. Regards. Bob
Old Jun 27, 2003 | 08:24 PM
boblite44's Avatar
boblite44
O, something I rorgot to mention. Before new MC installed, I noticed that when the engine was off, the brake pedal met very firm resistance after about half inch of travel no matter how often I pumped on it. Was this meaningless, or did it mean the MC in fact was working right ?
Old Jun 27, 2003 | 10:41 PM
S2Kev's Avatar
S2Kev
Thats normal because of the pressure built up inside of the brake booster. It has nothing to do with your master cylinder.
Old Jun 28, 2003 | 07:18 PM
boblite44's Avatar
boblite44
Thanks so much for the info. Regards. Bob
