electriccal problems
Old Jan 4, 2003 | 03:59 PM
brak's Avatar
brak
37 ?!
Default electriccal problems
in my civic, on the highway, going to work this morning, about half way there, my CEL comes on and the speed-o starts going back and forth like crazy, so i pullover, pop the hood, no visible problems, engine temp is normal, so i head to work. get there, try to get the CEL codes, and come up with 20, 41, and 65. talk to some people and get opinions, a friend comes and looks, say it's the alternator. then after my shift ends, i bring it to the mechanics at work, and they say the alternator and battery are both bad. anyone one else have any expierence with this, and have advice ?
Old Jan 4, 2003 | 05:07 PM
brak's Avatar
brak
37 ?!
so silent...
Old Jan 4, 2003 | 05:22 PM
Redcivic's Avatar
Redcivic
One of the original OG's
Well, take the car to autozone and get the battery and alternator tested. is their a lot of corosion on the battery terminals?
Old Jan 4, 2003 | 08:02 PM
brak's Avatar
brak
37 ?!
that's what i did (work = pepboys). the battery came up as bad, it holds charge, but barely. and i didnt take off the alternator to put it on the machine. but that seems to be going too (the charge it's putting out isnt steady at all). i was just wondering if anyone knew any other causes, besides the battery and alternator.
Old Jan 4, 2003 | 08:51 PM
inspyral's Avatar
inspyral
のんびり~(´ε`)
20 is the Electrical Load Detector or ELD. It's built into the fuse box.
41 and 65 are the primary and secondary O2 heaters.
Before replacing the alternator or battery, I would check the alternator/VSS fuse under the dash. I went through 3 batteries and 2 alternators when I had a similar problem. My alternator wouldn't charge my battery and eventually the battery would die. My speedometer also worked spradically. After swapping batteries and alternators, I checked all the fuses, and the VSS/ALT fuse under the dash wash out. Replaced that, and everything was gravy. If there's noting wrong with your O2's and your VSS/ALT fuse is out, replace it and reset your ECM. Your problems should go away.
Old Jan 4, 2003 | 09:02 PM
brak's Avatar
brak
37 ?!
that sounds like a strong possiblity, thanks inspyral. i hope it works, replacing the alternator was the last thing i want to do.
Old Jan 5, 2003 | 10:56 AM
Bakeoff's Avatar
Bakeoff
wooooo woooooooooo
Inspyral sounds like he's right. The only other thing I would think of checking would be the plug on the top of your tranny. It's for the speed sensor. It has 3 wires coming out of it. If that has wiggled loose, it may be contributing to your problem.
Old Jan 5, 2003 | 02:47 PM
brak's Avatar
brak
37 ?!
i replaced the fuse, and everything was fine. and then 2 minutes later the fuse popped again.
Old Jan 5, 2003 | 04:21 PM
inspyral's Avatar
inspyral
のんびり~(´ε`)
Have you done any electrical work to the car recently?
Old Jan 5, 2003 | 06:00 PM
brak's Avatar
brak
37 ?!
nope, not in quite a while
