electriccal problems
Old Feb 21, 2003 | 03:14 PM
brak's Avatar
brak
37 ?!
my car is still popping fuses, the 7.5 alt fuse kept popping, and i put a 10 in it, and it stopped, but the lights would dim at idle, and the car would sometimes stall at stops. and if my headlights were on, the interior lights would dim if i put on high beams. now the car is popping the 10 amp fuses. and if i have the headlights are on, they (and all the other lights) will pulse. it did that before when the 7.5 fuses were poping.
im pretty close to buying a new alternator, im wondering if there's anything else i can do.
any ideas ?
Old Feb 21, 2003 | 04:31 PM
inspyral's Avatar
inspyral
のんびり~(´ε`)
Let me know if you want an alternator, or check out the link in my sig.
Old Feb 21, 2003 | 07:27 PM
brak's Avatar
brak
37 ?!
i just wanna make sure the alternator is the problem, i dont wanna replace it, and then still have the problem.
Old Feb 23, 2003 | 02:06 PM
brak's Avatar
brak
37 ?!
anyone know if a slipping belt could cause my problems ?
Old Feb 23, 2003 | 02:18 PM
Hondaman's Avatar
Hondaman
Black Pearl
Do you by chance have an aftermarket radio in there with the stock unit burried in the dash???
Old Feb 23, 2003 | 02:28 PM
brak's Avatar
brak
37 ?!
nope, just the aftermarket in there
Old Feb 23, 2003 | 03:17 PM
Hondaman's Avatar
Hondaman
Black Pearl
I had a problem with my 96 LX that did the same thing. What had happened was Best Buy buried the factory radio in the dash and it pinched and or shorted a wire and burned up the voltage regulator in the alt. and caused it to over charge. It blew the alternator and did the same thing that you are describing. The speedo is electronically controled so if the the electronics get messed up, it will do that.
The story has a happy ending though. Best Buy forked over $800 to get my car fixed.
Old Feb 23, 2003 | 03:24 PM
brak's Avatar
brak
37 ?!
u dont happen to know what wire they pinched ?
Old Feb 23, 2003 | 03:29 PM
Hondaman's Avatar
Hondaman
Black Pearl
:dunno: It was behind the dash though, obviously. You said you are popping fuses, you can try tracing that one to see if you can find anything(ie, grounded somewhere, or pinched.) I'll do some searching to see what I can figure out.
Old Feb 23, 2003 | 03:30 PM
brak's Avatar
brak
37 ?!
kool, thanks
