ride is crappy, shocks or springs?
Old Oct 29, 2008 | 05:48 AM
JoePoonani's Avatar
JoePoonani
Lexus Tech y0!!
Originally Posted by myGFsIntegra
do you think i'll need a camber kit if its only supposed to drop it 3/4 in? I don't even know if it'll be that much compared to my saggy stock ones.
Any time you do suspension work(especially height adjustment) you should get the car aligned.
Old Oct 29, 2008 | 06:06 AM
myGFsIntegra's Avatar
myGFsIntegra
I was planning on getting it aligned, but I'm unsure if I need a camber kit for this small of a drop. guess i'll find out when I get it on there
Old Oct 29, 2008 | 12:02 PM
dieneverknowing's Avatar
dieneverknowing
I really wouldn't imagine that with the small of a drop that it couldn't be adjusted to be within spec. But that's the thing that sucks about lowering, is wondering if you need a camber kit. You can't tell for sure if you need one till you align it, then you'll have to realign it if you do need and install a kit. I know no one likes wasting money. h:
Old Oct 29, 2008 | 02:05 PM
JoePoonani's Avatar
JoePoonani
Lexus Tech y0!!
To be safe I would get one for the front at the very least.
Old Oct 30, 2008 | 06:12 AM
myGFsIntegra
well, I'm gonna take my chances. Most of what I've read says I wouldn't need one for a drop of less than one inch. I was supposed to have everything on there today, but UPS is taking their sweet time with my shocks and they won't be here until tomorrow. Guess that means I won't have them on my car til i have some free time next week. I'll let you guys know what comes of it
Old Dec 7, 2008 | 07:27 PM
myGFsIntegra
i don't know if anyone cares, but i do have an update. This combination of shocks and springs is fantastic. I did the install with the help of a write-up on this forum and it went very well except for two problems. The first was a seized bolt that i broke the head off of. $200 later, i had a new control arm installed.
the second kinda sucks. I am hearing a rubbing/squeeking that sounds like its coming from the driver's side front. it coincides with the extension/compression of the suspension. sometimes its worse than others and it may or may not be worse when it's cold out. any ideas?
edit: the squeaking sounds more like a rubber squeak as opposed to a high pitched metal squeak
