Possible Causes of bad gas mileage?
Old Nov 26, 2002 | 03:24 PM
derf's Avatar
derf
Spec5
Originally posted by derf
what is a MB booster?
some more info on my situation.. my poor gas mileage happened almost immediately after I replaced my ignition coil, cap rotor and plugs. Like I said they use to be.060 inches and now the new plugs are at .040 (factory)
I was going to check for any codes the car might throw....asiandood, how do I get to that two prong connector? i looked and looked but I couldn't find it?
what SHOULD the residue on the o2 sensor look like when I remove it?
no answers? could the o2 senser throw it off that much?
Old Nov 26, 2002 | 03:45 PM
crucial Si's Avatar
crucial Si
Banned
it occured to me to check the 02 sensor. I keep a book of every gas fill up I have ever put in my car. last two fillups are 22 and 23 mpg.
MB booster is what goes into the firewall and what controls the brakes. its what the MB cylinder goes into.
Old Nov 26, 2002 | 04:51 PM
derf's Avatar
derf
Spec5
oh i just call it a master cylinder
Old Nov 26, 2002 | 05:57 PM
agent87's Avatar
agent87
Need zzzzz's
You might not have any codes but here ya go:
http://www.c-speedracing.com/faq/06.html
Old Nov 26, 2002 | 06:56 PM
popag99's Avatar
popag99
im having the same problem. here is a link to the part of the forum where i have had some answers. https://www.honda-acura.net/forums/s...threadid=34495
Old Nov 30, 2002 | 11:22 PM
derf's Avatar
derf
Spec5
timing is fine, i checked today... no codes....
can someone give me a straigh answer as to what the o2 sensor shoudl look like? white, black, etc? anyway to test it?
Old Dec 27, 2002 | 06:55 PM
livelyjay's Avatar
livelyjay
I ran a search because I'm having a similar problem with gas mileage.
If you pull off the O2 sensor there will probably be a lot of carbon material on it, much like what you see on the inside of your exhaust tip. If it was giving a bad signal, or was not working properly, your engine light would go on. I ran into this problem when I had a shop install my exhaust. If you do take it off, clean it up, replace, reset ECU, and see what happens.
Other things to check for:
Clogged air filter
Bad spark plug wires
Misfiring spark plugs (this may be caused by the previous suggestion)
Clogged fuel filter (replace this if you haven't done so)
When you replaced the cap and rotor, where did you get the parts from?
Old Dec 27, 2002 | 11:30 PM
derf's Avatar
derf
Spec5
www.thepartsbin.com I ordered $50 worth of stuff, saved a bundle and since it was >$50 shipping was free
Old Dec 27, 2002 | 11:34 PM
dom93hatch's Avatar
dom93hatch
more meat, more fire
Could also be bad gas.
I filled up at this one ghetto place because 87 was cheap, but got sh*tty mileage. I think I got ~220 on that tank. Next tank was at Arco, where I got ~300.
Old Dec 27, 2002 | 11:39 PM
derf's Avatar
derf
Spec5
i get mobil every single time. like i search for mobil gas stations
