Possible Causes of bad gas mileage?
Old Nov 21, 2002 | 06:12 PM
asiandoood's Avatar
asiandoood
sancho on the sizzide!
02 sensor?
driving habits?
Old Nov 21, 2002 | 06:37 PM
crucial Si's Avatar
crucial Si
Banned
Originally posted by asiandoood
02 sensor?
driving habits?
i doubt its driving habits...i wrag the shiit out of my car most of the time, and i still get 290+ w/ a/c on half the time.
well i havent been getting over 250 due to my brake issue..
Old Nov 26, 2002 | 12:05 AM
derf's Avatar
derf
Spec5
what is a MB booster?
it occured to me to check the 02 sensor. I keep a book of every gas fill up I have ever put in my car. last two fillups are 22 and 23 mpg.
some more info on my situation.. my poor gas mileage happened almost immediately after I replaced my ignition coil, cap rotor and plugs. Like I said they use to be.060 inches and now the new plugs are at .040 (factory)
I was going to check for any codes the car might throw....asiandood, how do I get to that two prong connector? i looked and looked but I couldn't find it?
what SHOULD the residue on the o2 sensor look like when I remove it?
derf's Avatar
derf
Spec5
the air fuel mixture is controled by the ECU right? there is no way to manually adjust the air/fuel on a stock engine?
Old Nov 26, 2002 | 05:42 AM
Mike's Avatar
Mike
Banned
Default Re: Possible Causes of bad gas mileage?
Originally posted by derf
Why could I be getting such bad gas milage? I'm at half a tank or less after 120 miles. new fuel filter, cap, rotor, ignition coil, spark plug....?
no more draggin on brakes... what else?
1) Bend over
2) Remove the lead foot
3) Instantly gain better gas mileage.
Mike
Old Nov 26, 2002 | 06:02 AM
CivicSiRacer's Avatar
CivicSiRacer
Honorary Moderator Alumni
Also as the colder weather sets in air is denser so it contains more oxygen. More oxygen requires more fuel.
Autocross Help Page
Old Nov 26, 2002 | 06:07 AM
randomtask77's Avatar
randomtask77
Wanderer
Did you check your tire pressure as well? Don't know if that was brought up, I didn't read the previous posts...
Old Nov 26, 2002 | 06:50 AM
CivicSiRacer
And I was just about to post that too Colder temps mean lower tire pressure.
Autocross Help Page
Old Nov 26, 2002 | 07:17 AM
HLD_Civic's Avatar
HLD_Civic
se7en
maybe too much street racing! hahahahah just kidding
Old Nov 26, 2002 | 09:05 AM
derf's Avatar
derf
Spec5
i don't think the cold weather would make me drop 10 mpg.... and I let the car shift under 3... this time and I only got 23mpg
