Brake Noise
I have a 93 Si and whenever i break i hear weird noise in the back of my car sounds like the brakes...it sounds like if you put some rocks in a coffee can and rolled it around...its hard to explain...gimme some help
Originally posted by 96extec
I had that noise in my brakes, it hought it was the drum's, it turned out to be a big pile of brake dust. i took them off and blew them out and there still fine. may be diffrent in your case.
but that graveling noise is usually metal on metal components.
Originally posted by fujiwara takumi
yeah, that sometimes works, you can get a can of aerosol brake cleaner and probably take care of it...
I suggest cleaning them out and looking at how much pad you have left.
Originally posted by westcoaststyle
If you did put a groove in your drums, you can get them turned (depending on how much of the drum surface is left)
I put new shoes on the back of my LX last year, and ever since I did, it makes a grinding sound when I stop. I don't know why. I've pulled them apart numerous times to check and recheck them and haven't seen anything that makes sense. I used genuine Honda pads too. They are wearing fine and don't cause any problems other than noise. Just luck I guess.
As far as measuring pad life. That's really hard to judge. It's dependent on how often you stop, and how hard you stop. Usually I just do the rear ones the same time as I do the front ones. This is of course on a car with rear drums. With rear disk, you should have an indicator scraper that makes noise when they need to be replaced.
Tom
Tom
:thumbup:
