Help: broken wheel stud!!!!!!!!
Old Nov 2, 2002 | 03:32 PM
bokchoyboi's Avatar
bokchoyboi
Default Help: broken wheel stud!!!!!!!!
damn i've been having the worst luck ever since i cracked my freinds (ElectronBlueGSR) passenger mirrors oh Holloween. well anyways today i was taken my GSR rims off cuz i'm selling them and i broke one of the wheel stud. Its the front driver side too, so rite now it i only have 3 lug nuts on it and i'm worry about it. Is there anyway i can fix it or get the whole thing? If so how much would they go for and if i can fix it how? If anyone total his/her car and have one please let me know. By the way my car is a 2000 civic ex coupe. Thanx...damn still 7 more yrs. or bad luck i guess.....lol
Old Nov 2, 2002 | 03:56 PM
bokchoyboi's Avatar
bokchoyboi
well i ask a friend and he said i can just get a new stud for like $4 at a Honda Dealership.
Old Nov 2, 2002 | 04:03 PM
jollibee's Avatar
jollibee
take it to a shop. it cost about 8 bux each stud including labor.
Old Nov 2, 2002 | 05:27 PM
bokchoyboi's Avatar
bokchoyboi
thanks for the info, i'll just get a new stud at a shop
Old Nov 2, 2002 | 06:30 PM
tokyoracer's Avatar
tokyoracer
got JDM milk???
dude... u can just do it urself. it's not that hard. i did that for my friends twice... one on a corolla, and then another on galant. if you need the steps... let me know.
Old Nov 2, 2002 | 08:11 PM
Max Power's Avatar
Max Power
Buff Member
one of my lugs is busted also but for hondas i guess its not that easy. an independent shop said that it couldnt be knocked out and that they'd have to take out the whole hub. . . . 40+ bucks.
Old Nov 2, 2002 | 08:14 PM
frank's Avatar
frank
frank from canada
well it actaully can be knocked out but it can't be knocked in without taking the whole hub off.
my friend slipped with the hammer once and he messed up the studs on my rear wheel so we took off the hub and hammered the studs out and then hammered the studs back in so now its all good.
Old Nov 2, 2002 | 08:17 PM
crucial Si's Avatar
crucial Si
Banned
ever since i bought my car back in feb it had a broken stud...i still havent fixed it...i have no problems.
Old Nov 2, 2002 | 08:40 PM
bokchoyboi's Avatar
bokchoyboi
send me the steps pn how to fix it..thanx
Old Nov 2, 2002 | 08:46 PM
tokyoracer's Avatar
tokyoracer
got JDM milk???
humm.. getting it back in is not that hard. u don't need to remove the hub. the ghetto style we did was turn the hub to a point where you can get the most leverage to pound part of it in. before putting the stud back in... i suggest some wd40.
once the stud is there and it doesn't move around.. then put ur brake rotor back on and the wheel back on. and then slowly tighten the nut onto the stud. don't do it too fast or hard... don't wanna strip the screw. take ur time on this.. if you have an impact wrench... it'll be easy. then after u screw it on... take the nut off... and the wheel... and the brake rotor... then stick ur head behind the hub.. and VOILA... it's in. then after that.. u might have to bleed ur brake a bit just to be able to push the piston into the caliper... but sometimes, it'll fit back on without bleeding. so... if you have more questions... feel free to ask.
P.S. make sure your car is safely jacked up and resting on jack stands. i usually leave the jack there along with the jack stand.... just to be safe.
