Engine swapping and turbo ideas
Heh you are in the exact same position I am in
I say turbo. With the same amount (4800? damn thats more then enough for the turbo
) you can get more power/torque. You can also save some if you search for parts.
Ex intake manifold (I got mine for 150 complete)
exhaust manifold (HF manifold off a 88-91 CRX with a adapter plate welded on. Or something like a Greddy manifold. Full Race had a GB a while back on manifolds)
turbo (14g off a DSM or something)
wastegate
piping
SMC with DSM 450cc injectors for fuel management ( I think diablo motorsports had it. 280? I dont remember.)
turbopanda's 1st gen Supra piston/B16 rod combo for 500.
He was running 1.2 bar (whats that? ~15 psi?) going down the 400m (guess thats about the 1/4 mile heh) in a fully loaded sedan 13.4 @ 183km/hr. You can do the converting
And a side mount IC. Off a Starion or something.
) you can get more power/torque. You can also save some if you search for parts.Ex intake manifold (I got mine for 150 complete)
wastegate
piping
my bum is on the swedish!
wastegate
piping
wastegate
piping
Just the post I was looking for. But could you go into a bit more detail? The exhaust manifold part on is a bit confusing (DSM? SMC?) Forgive my ignorance, but boost is new to me.
I was doing a lot of research. But then I realized I'd need at least 2500. Figured I'd just get a bike instead
HF manifold page
Might have to try a couple times. Runs out of bandwidth fast.
Copied pasted from HT
"The SMC is an acronym for Super Map Controller. The SMC features:
-Controls larger injectors up to 440cc to 450cc for FI setups with factory ECUs
-Real-time MAP voltage correction for unparalleled drivability under idle, daily driving, and boost
-Smoothens transition from vacuum to boost
-Active internal MAP clamping to prevent a check engine light*
-User programmability
-Fuel trim, up to -55%, on four rpm levels
-Precise idle fuel control
-Unlimited rpm range
-Ultra-fast 20MHz RISC processor
-Easy installation
-works from 1-13psi of boost (injector size dependent)
-Stealth. Small and compact design
-Works with other factory NA engines and factory boosted engines with a MAP sensor "
Full article
HF manifold page
-Easy installation
Full article
Originally posted by asiandoood
$4800 installed? Thats quite high. The engine alone is about 3200-3500 plus or minus 3-500 for shop installation. Where is that other 800 going to?
Originally posted by Phat
4,800 i got auto - manual swap parts, b18c1, jdm dc sports headers, apexi exhaust and clutch and lightened flywheel. labor is free
well just the motor but oh well
Originally posted by Jkan2001
Werd...that's too high. If you are interested i can get you a USDM 99-00 Civic SI swap for 2300+shipping.
Originally posted by SirSmokeAlot
but like I said, thats including install ($55 an hour). I'm sure the engine itself is much cheaper.
:fawk:
:fawk:
do you think I could somehow fit an ex turbo onto an lx, with moddification to the intake manifold and exhaust?
what I'm thinking is getting an ex intake manifold, a turbo kit for an ex, and redoing the exhaust, new cat, etc. Would that work?
