want to get coilovers for my 00 civic! any recommendation would be nice
Old Oct 14, 2007 | 02:50 PM
dranom's Avatar
dranom
Default want to get coilovers for my 00 civic! any recommendation would be nice
hey guys! im new to this and
i want to lower my car a bit to give it that look.
I saw a skunk coilover kit on ebay
here:
SKUNK COILOVER
is this ok? coilovers has shocks in it already right?
Also if any one who has this particular set hows the ride???
my budget is not that high so if ever your gonna recommend a different set pls dont go over $1000
Thanks for the help in advance!
Old Oct 14, 2007 | 05:43 PM
slintegra's Avatar
slintegra
IMO lowering springs are better but if ur not sure how low u want it then coilovers are always good in that situation, they have this piece that goes in the bottom of the spring and most likely it will come with a tool so u can adjust it by pulling the top half one way and the bottom half the other. I've had different experiences with coilovers so i wouldnt be able to tell ya exactly. hope i helped
sean
Old Oct 14, 2007 | 05:48 PM
Civic2Scooby's Avatar
Civic2Scooby
http://www.omnipowerusa.com/product.asp?P_ID=121
and no the skunk2 coil overs don't come with struts. They are just a sleeve.
Old Oct 14, 2007 | 09:29 PM
dranom's Avatar
dranom
what do you mean about "dont come w/ struts"?
sorry noob!
So that link on ebay isnt plug and play?
Old Oct 15, 2007 | 12:09 AM
1 quick sol's Avatar
1 quick sol
OK, the skunk 2 setup you are looking for seems to be a decent entry level set up, I don't care for it because it does not have dampning adjustment, or a seprate ride height/ spring preload setting, but if you are just looking to slam your car, they should work pretty well. Then you have the option of the so called coild over that goes on your orginal strut, basically a threaded sleeve, and a short spring, even though these are much cheaper, stay away, within a few months of these on your side, your struts will be junk, so if you plan on going with this, plan to buy struts that were designed for lowered cars. Hope this helps, oh by the way dont' forget to get your camber kits no matter what option you go with
Old Oct 15, 2007 | 12:34 AM
dranom's Avatar
dranom
ic. thank you for your info. so can you link me some good ones but a bit low on price? i saw one on the for sale threads a skunk coilover w/ kyb shocks(the one w/ the adjust thing)
about the camber kits w/c is a good low priced one?
Old Oct 15, 2007 | 05:50 AM
Civic2Scooby
those omni's will be your best bet for a good price. They are about the only entry level coilover setup that I would put on my car.
Old Oct 15, 2007 | 08:33 AM
goon54's Avatar
goon54
+1 i had these on my 99 coupe. easy to install, dont need any spring compressors, a decent ride, and they hold there own when u push thru the corners.
Old Oct 15, 2007 | 11:07 AM
dranom's Avatar
dranom
so this omni power is just plug and play right? install and ready to go?
just adjust height and 4 wheel alignment?
im also wanna get an ASR sub frame brace w/ some sway bar and lcas
Old Oct 15, 2007 | 02:16 PM
RunningOnMT's Avatar
RunningOnMT
4Banger
For your budget, I recommend Tein Basic Dampers or a used set of the Super Street version. You will get a better ride quality over the Skunk2 and Omni. Tein USA provides support such as rebuilding.
Another option is a combination of Ground Control coilovers and Neuspeed/Koni SP3 shocks. You can add little things like the Ground Control tophats for 3/4 in more travel and Koni bumpstops to lessen the impact of bottoming out. A big plus is that you can change springs with different rates for street or track. You could get the tophats later if you need the extra travel, since the SP3 is already a shorten body shock, to keep yourself under budget.
