Timing belt install on 94 civic ex help/question
How do my taillights look
i do have the Chiltons manual for the car...which helps a lot but people had step by step instructions with pictures for my GSR...Chiltons doesnt have as many pics.
i think ill go with ordering from here.
http://www.prostreetonline.com/a/hon...-belt-kits.asp
i think while im there i might adjust the lifters too.
DOHC wasnt too bad as long as none of the pulleys/cams moved.
Never understood TDC though. I know theres a mark on the cam butu should the mark face straight up towards the sky or angled up with the angeled motor?
ok i have everything from the dealer. everything is on the car. install went well
timing is set
ONLY PROBLEM is the belt is walking it self off when i turn it over manually to check timing?
WHY?!?!
thanks
timing is set
WHY?!?!
thanks
yea but when checking timing the cover is off.
I made more tension on the belt and it preeeeeeeeetty much doesnt walk off anymore...well kinda...
gotta look into this more
