vtec question
Old Aug 30, 2007 | 10:21 PM
A-series's Avatar
A-series
v-card member alpha
Noone's perfect, esp. when it's late.
To show you what I know, I wish mine switched the exhaust instead of the intake (changing plugs would suck ass though) and I don't even know if that make sense, or would work h:
Old Aug 31, 2007 | 09:44 AM
ddd4114's Avatar
ddd4114
Originally Posted by sherwood
You're on crack, I have never heard of a mechanical VTEC failure in my LIFE.
The reliability of the VTEC system is not the limiting factor for either.
I never said he's going to have a failure. In fact, I highly doubt that will ever happen.
non-vtec:
less moving parts
easier to tune
vtec:
eats oil (ok, a slight exaggeration...)
Plus, you can run a bigger cam in a non-vtec head
Overall, this is an irrelevant debate. This is like arguing which would make a stronger letter opener, stainless steel or an aluminum alloy. VTEC is a great technology. There's no debating that.
Also, what's wrong with 5th gen transmissions? Or are you just referring to autos?
Old Aug 31, 2007 | 01:19 PM
Snoopy's Avatar
Snoopy
been there done that
and have a shitty idle. run that same profile on a vtec cam and you can have a smaller primary.
Old Aug 31, 2007 | 01:27 PM
sherwood's Avatar
sherwood
I missed Sean
Which, if you're still learning is the entire point of VTEC in the first place. To achieve a smooth torque band from idle to a high redline.
Old Aug 31, 2007 | 01:59 PM
ddd4114's Avatar
ddd4114
<<< means I didn't mean for you to take the comment that seriously
I know the point of VTEC, and as I already stated:
Overall, this is an irrelevant debate. [...] VTEC is a great technology. There's no debating that.
Old Aug 31, 2007 | 02:37 PM
bighroder's Avatar
bighroder
is vtec the only dohc motor or is there other dohc motors or should i just get a sohc motor?
Old Aug 31, 2007 | 02:46 PM
sherwood's Avatar
sherwood
I missed Sean
There are variations on both, I'd highly suggest a VTEC DOHC enabled car featuring either a B16/B18c, H22 or K series engines
These engines are smooth, potent, and above all just fun. Their featured models also generally sport the highest technologies available from Honda at that given time, so they are really great cars.
The SOHC VTEC designs usually showcase an improved torque band over the same rev range, or better gas mileage in the same rev range as their non-VTEC counterparts.
BUT this all really depends on what you want in a car, if you give us a better description of what you're looking for we will probably be able to point you in the right direction, whether the car be a Honda or not.
Old Aug 31, 2007 | 03:57 PM
Snoopy's Avatar
Snoopy
if you're still confused about what vtec is, here:
http://auto.howstuffworks.com/question229.htm
http://www.youtube.com/watch?v=AcT_ZyY3F0k
Old Aug 31, 2007 | 04:03 PM
Kabooki's Avatar
Kabooki
I dont understand one thing. (Just thinking aloud here) How can a SOHC vtec only adjust the exhaust lobes? Intake and exhaust ride on both outer lobes, when vtec "kicks in" the solenoid opens alowing oil pressure to lock pins in the rocker arm thingies which locks the outter rockers riding on the outer lobes for each cylindar to the inner arms which ride the inner lobe which has a higher lift profile. This in my theory would mean that both intake and ehaust recieve the exact same added lift/duration. Even the diagram from howstuff works theoretically suports my theory. Is there any facts about how vtec can only engauge on the exhaust (i heard intake sometimes too) side.
I dunno, but im still thinking about this one...
Old Aug 31, 2007 | 04:42 PM
sherwood's Avatar
sherwood
I missed Sean
I was incorrect, It adjusts only the intake lobes.
The reason is because the spark plug holes rest between the exhaust valves, preventing an extra rocker arm from being added in that location.
