After a couple years of waiting.......I get to start my GSR build
Old Nov 12, 2008 | 06:12 PM
  #151
Jafro's Avatar
Jafro
I'm made of meat!
Originally Posted by HatchVX
Well after measuring everything up i had to tear the block down again so that i can get the mains line honed.
Here are the measurements Crank 1) .1906 2) .1906 3) .1894 4) .1907 5) .1907 Block 1) .1914 2) .1911 3) .1924 4) .1921 5) .1928 Which yeild these clearences 1) .0008 2) .0005 3) .0030 4) .0014 5) .0021
Once i get the block back i will measure the mains and figure out what bearings i need to get. One of these day the motor will be in and running.
Oops... epic fail.
So basically #4 is right. I think you've figured out why #1 & 2 were so bad. If I saw these #'s, I'd align bore it. It's okay if #3 is a lil' on the loose side for the crank, but the block seems to be where all the variance is. The reason why I'd align bore it is so I don't have to buy several sets of bearings to piece together a fix for that. You want to be able to replace them with 1 standard set, or one off-sized set if you can.
Old Nov 12, 2008 | 08:32 PM
  #152
Civic2Scooby's Avatar
Civic2Scooby
align hone FTW. sounds like you should have done that from the get go. Not to be a dick, buy with all you have into this why didn't you do that from the get go?
Old Nov 12, 2008 | 09:22 PM
  #153
HatchVX's Avatar
HatchVX
Driving a Turbo 2L Terror
I contacted the guy i bought the motor from, and he said it was running fine, no problems with the bearings.
Jafro the spun rod bearing was from the first block i bought. I will call around some other places to see what their rates are.
Old Nov 15, 2008 | 07:16 AM
  #154
Jafro's Avatar
Jafro
I'm made of meat!
I know about the motor, you 'splained that on the phone... I think you misunderstood me. My post was edited because at first, I replied to you just quoting you, and that was all I posted. I had to edit in my response, so I <me epic failed at interweb. Not you. I epic failed like the epic.fail.guy. I'm not breakin' your balls. The HAN server probably mailed you an update with just your post in it... just to prove my epic fail.
I used to post funny shit when I'm sick. Now I should just stay in bed. I'm old.
Old Nov 15, 2008 | 07:19 AM
  #155
Jafro's Avatar
Jafro
I'm made of meat!
Just to echo Civic2ScoobyNback, you'd probably just need it honed. Align Bore is probably overkill because they have to shave the main caps and cut a new hole. A good hone would probably even 'er out.
Old Nov 15, 2008 | 07:48 AM
  #156
Running925's Avatar
Running925
Your Powder Coater
Originally Posted by Jafro
Civic2ScoobyNback
lolz
Old Nov 15, 2008 | 11:24 AM
  #157
HatchVX's Avatar
HatchVX
I dont know why i didn't think of the align hone before. I misread Lee's post. I have to call on monday they are all closed on sat. :sad:
Old Nov 15, 2008 | 05:22 PM
  #158
fathergoat's Avatar
fathergoat
:3
Never give up, never surrender!
Old Nov 16, 2008 | 06:43 AM
  #159
Bumnah's Avatar
Bumnah
So OG it hurts.
I hope your motor is up and running soon. Do you remember what we spoke about when I came by to pick up those parts?
Project EVA - The Track Package
Project EVA
Old Nov 18, 2008 | 08:08 PM
  #160
HatchVX's Avatar
HatchVX
Cant say that i do, it was a while ago.
