my POS wont start! ohnoes!!
Old Mar 10, 2007 | 08:41 AM
Snoopy's Avatar
Snoopy
been there done that
Originally Posted by Ra005e
Well I know some relays are in the fuse box under the hood (found that out recently) and obviously I'd look there for a fuse also
This may seem unlikely but I'm not 100% convinced that it isn't the battery. Did they test it before you purchased it?
A while back I didn't find out a battery that I purchased had lost it's charge sitting on the shelf (presumably b/c not as many small cars w/ small batteries in my area) until after it was in the car
If I remember correctly, the car turned on and all that but wouldn't turn over. A second battery, that was checked first of course, solved the problem.
i took the original battery to autozone and they threw it on the charger for an hour. i came back and it was still very low so i just bought the new one. after i put that one in i got power back but still no start.
Old Mar 10, 2007 | 10:30 AM
Civic2Scooby's Avatar
Civic2Scooby
does it click or just nothing....if you have a set of jumper cables you can jumper the starter...if it cranks the engine than you know its a fuse/relay ...if it doesnt than you know you have a bad starter.......use your head :fawk:
Old Mar 10, 2007 | 04:52 PM
JoePoonani's Avatar
JoePoonani
Lexus Tech y0!!
I had the same situation that you had with the cranking but no start, I replaced the coil in the dizzy and it did the trick. Are you getting spark?
Old Mar 28, 2007 | 02:11 PM
Snoopy's Avatar
Snoopy
UPDATE!!
finally go the damn thing started. turns out it was the ignition fuse under the hood. since i didnt have a spare fuse at the time i took the one from the option position since they're both 50a. that started it up instantly. i go buy a new fuse to replace the one i took off the option but now with that fuse in i can roll down the windows but i get no start. if i take it out i can start the car but the windows wont roll down. :wtf: :madr:
Old Mar 29, 2007 | 04:00 PM
Snoopy's Avatar
Snoopy
hello out there
Old Mar 29, 2007 | 04:18 PM
JoePoonani's Avatar
JoePoonani
Lexus Tech y0!!
Did you put the 50 amp fuse back in the option spot?
Old Mar 29, 2007 | 06:11 PM
Snoopy's Avatar
Snoopy
yep bought a new one for it. i'll rephrase, with both fuses in the windows and sun roof work but no start. with the option fuse out i get start but no windows.
Old Mar 29, 2007 | 06:51 PM
F22B Prelude's Avatar
F22B Prelude
Rachel Bilson
Does it start now?
Old Mar 30, 2007 | 10:28 AM
Snoopy's Avatar
Snoopy
