cant i replace my DX gauges with VTi gauges with rpm...the dx gauges haven't a rpm...
Old Oct 6, 2002 | 09:11 AM
loodboi's Avatar
loodboi
هونده بريلود
Originally posted by spankaveli
all the harnesses are the same. the wires there, the cluster just doesn't have anything for the wire to do, so it just sits there. it's simply Plug&Play
man it sound like u have done this before???did u do this before??
Old Oct 6, 2002 | 05:38 PM
Louie3252's Avatar
Louie3252
yea. im slow... DX
yea i putta Ex cluster in my 98 Dx... it was plug n play.. same red line at 6800... so its cool.. get the Si cluster if ur gunna get an engine that reves to 8.. and it looks cooler :thumbup:
Old Oct 7, 2002 | 07:23 AM
spanky's Avatar
spanky
I go duffy on dem bitches
i did something a little more complicated but i know that it works. i sold my stock ex cluster to my friend with a hatch, plug in and it worked. nothing else needed
Old Oct 7, 2002 | 07:54 AM
mobius's Avatar
mobius
i did a 6th gen ex in my dx and it works fine. the only problem is it is not completely accurate, but who sits there and stares at their tach while they are driving anyway...... mostly you go by feel.
Old Oct 7, 2002 | 09:18 AM
loodboi's Avatar
loodboi
هونده بريلود
what do u mean?? do u mean that it'll not work correctly??i mean doesn't the rpm tach go correct??and the ex engine isn't like the dx engine...so is the redline the same??i mean the LX have the same engine and the redline is 6800rpm...but on the EX...how much?
Old Oct 7, 2002 | 09:26 AM
mobius's Avatar
mobius
YOU CAN USE YOUR SPEEDO FROM YOUR DX, BUT YOU HAVE TO REPLACE YOUR TACH AND FUEL/TEMP GAUGE. THE TACH IS DRAWN ON A CERTAIN RATIO TO MATCH THE EX ENGINE (AS IS THE SI TO THE SI ENGINE). IT WORKS PROPERLY, BUT ISN'T 100% ACCURATE.....SIMILAR TO HOW YOUR SPEEDO WORKS WHEN YOU GET BIGGER RIMS THAN STOCK. THE ORIGINAL SPEEDO GAUGE IS BUILT TO WORK WITH STOCK EQUIPMENT. WHEN YOU CHANGE THE STOCK STUFF, THE GAUGES WILL BE CLOSE ENOUGH. I FOUND THIS OUT WHEN A FRIEND AND I WENT ON A ROAD TRIP. HIS ODOMETER READ 325 MILES BEFORE WE FILLED UP, BUT MINE ONLY READ 309. I FOLLOWED HIM AND WE FILLED UP AT THE SAME STATIONS BOTH TIMES. MINE READ LESS BECAUSE I HAD BIGGER RIMS.
Old Oct 7, 2002 | 09:28 AM
mobius's Avatar
mobius
THE REDLINE STILL READS 6800, BUT IF YOU ACTUALLY GET TO REDLINE ON THE EX GAUGE, IT IS SCREAMING!!
Old Oct 7, 2002 | 11:09 AM
EX R8ED's Avatar
EX R8ED
is whipped
...and so are you with the caps lock on!
Old Oct 7, 2002 | 11:12 AM
mobius's Avatar
mobius
my bad.....work in architectural......I only use caps on the blueprint text. It's standard (to scream at people). lol
Old Oct 7, 2002 | 12:08 PM
loodboi's Avatar
loodboi
هونده بريلود
hahaha...maaaan why r u screamin on meeee??i wuz just wondering lol...maaaan...u mean if i change to the si or the vti whoz engine is more powerful...that i have to change the fuel tach and the temperature tach??or isn't it necessary?? have fun bro....and dont be aggresive...
