Engine Mounts
Old Aug 31, 2006 | 08:16 AM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
http://hondaswap.com/swap-articles/b...k-civic-54134/
http://hondaswap.com/swap-articles/6...verview-29118/
Old Aug 31, 2006 | 09:51 AM
asiandoood's Avatar
asiandoood
sancho on the sizzide!
i thought the only non-compatible teg->ek mount was the rear bracket being a little longer. You folks sure about that? :thinking:
top drivers side mount is totally different. rear bracket is different too.
Old Sep 1, 2006 | 10:28 AM
mberndt's Avatar
mberndt
Originally Posted by j32asc
What kinda mounts did you use? I would also recommend HASPORT. I havent had any problems with mine at all.
HASPORT's are over-rated... Just use Honda OEM parts that work with the motor in that car... Will save some $$ u can use for something else...
Old Sep 5, 2006 | 03:42 AM
93DituneEX's Avatar
93DituneEX
HIDs teh hotness!
Hey wassup to all u that know me, haha. Yea the EG died.......and I did too almost. Me and a buddy of mine rolled it four times, landed upside down, and then got hit in the drivers side by a cherokee so yea i'm lucky to be alive. But I got my old b16a out and built it a lil for boost and now trying get all the little kinks worked out that the last owner of my new shell left me: gonna replace the front suspension, replace straight pipe with hi-flow cat, put old muffler on, change out mounts, replace springs and buy struts, redo tint, paint front si grill, etc. so yea i got some work to do..........but if anyone wants to help me out i have a question, i have to have a obdII ecu to pass emissions, will a obdII gsr ecu with my chip work long enough to pass emissions or do I have to have one from a 99-00 si since thats the wiring harness i have on the engine? everything is already converted to obdII sept i'm using a conversion harness with my obdI ecu
Old Sep 6, 2006 | 05:51 AM
93DituneEX's Avatar
93DituneEX
HIDs teh hotness!
anybody know? need to know so i can pass emissions please
Old Sep 6, 2006 | 08:16 AM
Civic2Scooby's Avatar
Civic2Scooby
you need the Si ECU
