Engine Mounts
Old Aug 30, 2006 | 03:13 AM
93DituneEX's Avatar
93DituneEX
HIDs teh hotness!
Default Engine Mounts
I've got a 2000 EX with a b16A swap and I'm looking to replace my mounts, a couple are busted. What mounts would work? Mainly just the front tranny mount and the driver engine mount?
Old Aug 30, 2006 | 12:05 PM
j32asc's Avatar
j32asc
What kinda mounts did you use? I would also recommend HASPORT. I havent had any problems with mine at all.
Old Aug 30, 2006 | 12:42 PM
asiandoood's Avatar
asiandoood
sancho on the sizzide!
You can use the 99-00 Si Mounts....or go with Hasport.
Old Aug 30, 2006 | 01:15 PM
Running925's Avatar
Running925
Your Powder Coater
you can also use 94+ integra mounts
*edit.. & what happened to your old civic?
Old Aug 30, 2006 | 01:35 PM
asiandoood's Avatar
asiandoood
I dont think the upper side mounts are compatible on the 96-00 civic.
Old Aug 30, 2006 | 03:33 PM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
You're right. He'll need the Si mount for that application.
Whaddap, Joe?!
Old Aug 31, 2006 | 06:32 AM
j32asc's Avatar
j32asc
them mounts will only work with a 92-95 model.
Old Aug 31, 2006 | 08:04 AM
Civic2Scooby's Avatar
Civic2Scooby
wait, what the fuck happened to the EG?
Old Aug 31, 2006 | 08:08 AM
white_n_slow's Avatar
white_n_slow
it's my D in a B
i thought the only non-compatible teg->ek mount was the rear bracket being a little longer. You folks sure about that? :thinking:
Old Aug 31, 2006 | 08:14 AM
westcoaststyle
The center is the driver's side top mount for the 6th gen Civic.
