itr and ctr?
Old Aug 15, 2006 | 12:53 PM
Originally Posted by sherwood
the funny thing is you lose power when you do this. i love how these idiots think sometimes.
:werd:
Originally Posted by noscope101
Which is why I loove to beat them with my ls motor
No you wouldn't, unless you're a godly driver or the other driver sucks... they lose a minimal amount of torque in return for a little bit more HP
Old Aug 15, 2006 | 12:55 PM
sherwood's Avatar
sherwood
I missed Sean
Originally Posted by raiden571
.....the cams, the cams are why. gsr cams have more lift and duration then b16/b17 cams do. but then, ctr and itr cams are more agressive then that even. and im pretty sure that the valves and springs are stronger too. but, a gsr head does not flow as well as a b16 head does NA, but, under boost, a gsr head is more ideal because of the shape of the combustion chamber and i think the ports are different too, but, they also yield a higher compression. so, in my opinoin a true poor mans itr should atleast have the same valvetrain, other wise its nothing like an itr/ctr head
oye
stock flow:
PR3(B18)>P72(GS-R)>PR3(B16)
modified flow:
P72(GSR)>PR3(all)
compression:
P72>PR3(all)
as you can see modified the p72 will beat it out in both sections. unmodified the pr3 from the ITR has bettter flow, but the compression loss is greater than what is gained from the flow, so it's a mute point.
the gsr head is hands down the best b-series head that was produced, the only reason the ITR got the pr3 head is because there were too many stockpiled from the old b16's.
cam profiles are a whole other story, but it's not like it matters, without the compression to back up the more agressive profiles there isn't much to gain. the type-r merely overcame this by using pistons with an increased dome volume to increase compression.
Old Aug 15, 2006 | 12:58 PM
sherwood's Avatar
sherwood
I missed Sean
Originally Posted by RicoD
:werd:
there should be no horsepower gains at all with using a b16 head. the flow characteristics and combustion chamber volume are both downgraded.
the use of a type-r head will still have the same effect, with minimal if any gains in the top end.
an LS motor in a EG will most likely crush a castrated GS-R
Old Aug 15, 2006 | 01:41 PM
19.3secS2K's Avatar
19.3secS2K
my bum is on the swedish!
Originally Posted by ElCoqui19
Your right,it is a hatch,but I ment from the civic models as in coupe's and hatch's,the CTR is a hatch.
actually, they never sold the coupe civics over in japan.
3, 4, and 5 doors are the popular models
Old Aug 15, 2006 | 01:51 PM
ElCoqui19's Avatar
ElCoqui19
OHHHHH....cool,learn something new every day.
Old Aug 15, 2006 | 03:58 PM
noscope101's Avatar
noscope101
Eg_93_CPE
Or the fact is its a built and boosted ls thats an ass kicking machine
Old Aug 16, 2006 | 06:45 PM
raiden571's Avatar
raiden571
turning u inside out
[QUOTE=sherwood;3082769]oye
stock flow:
modified flow:
P72(GSR)>PR3(all)
compression:
P72>PR3(all)
cam profiles are a whole other story, but it's not like it matters, without the compression to back up the more agressive profiles there isn't much to gain. the type-r merely overcame this by using pistons with an increased dome volume to increase compression.[/QUOT
u listed that, but u did notshow at what rpm. the gsr head will out flow a b16 head up at around like 9.5k, but bottom mid and most of ur top end. not many people will rev there motor that high daily.
ITRinEJ1
Jul 10, 2004 11:58 AM
EJ6 Civic
92+ Civic/EL & Del Sol
2
Feb 6, 2003 10:59 PM
CivOnDubs
Engine Swaps, Tech & Tuning
6
Jan 5, 2003 01:12 PM
Import-Tooner
Nov 6, 2002 01:40 PM
Dr.Kimball
Oct 11, 2002 02:25 PM
