Upper control arms
Old Aug 8, 2006 | 02:54 PM
civicburner's Avatar
civicburner
Default Upper control arms
I went to get my wheels aligned yesterday, but the technician told me that he couldn't align the front passenger side wheel because the spindle was bent. He showed me how the wheel's camber was off. I rotated my tires today and the spindle looked fine, but the upper control arm was bent, so I think that's what is making the camber negative. Anyways how hard is it to change an upper control arm? Will I have to take off the entire shock?
Old Aug 8, 2006 | 07:07 PM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
Umm... Civic's don't have spindles...
Old Aug 9, 2006 | 03:17 AM
civicburner
...the knuckle
Old Aug 9, 2006 | 04:27 AM
m735is's Avatar
m735is
If you can remove the bolts from the back mount with the bushings, then no, you can replace the arm without removing the shock.
You can also just lower the shock and get the arm up over the top, then bolt it in.
Old Aug 9, 2006 | 07:58 AM
civicburner
Just to confirm, when you say lower the shock, you mean undo the bolts at the top of the shock in the engine bay, right?
westcoaststyle
what year civic is this?
Old Aug 9, 2006 | 08:20 AM
civicburner
96 coupe
Old Aug 9, 2006 | 08:30 AM
swaggs21's Avatar
swaggs21
Originally Posted by civicburner
96 coupe
look at my DIY for replacing them, not hard at all
Old Aug 13, 2006 | 10:15 AM
civicburner
Default Please Help
I replaced the upper control arm and my camber is still off. The knuckle really doesn't look bent, but else can be causing the camber to off?
Old Aug 13, 2006 | 03:13 PM
quik's Avatar
quik
1337 h4x0r
what about the LCA?
