block filling
Originally Posted by b18c1_hatch
you weld block guards in
Block guards are a waste of time and money. As long as the tune is good and detonation is eliminated, there really is no benefit of having a block guard since stock sleeves can hold plenty of horsepower.
I installed a block guard on my old LS and it went in so tight that it wouldent bounce around.
Originally Posted by Running925
so your telling me that pushing 400-500hp on stock sleeves isn't going to cause them to sway?.. i highly doubt this.. they are gonna move, the block guard will hold them from swaying
The detonation from a shitty tune will kill it regardless of whether you have a piece of metal reinforcing the cylinders or not. The swaying is very minimal.
But if it makes you sleep at night...
h:
http://forums.evans-tuning.com/viewtopic.php?t=1376
h:
h:Detination increases cylinder sway. so if you can get a perfect tune. then you lessen your chances, but there will still be movment. That is the reason for taking up the space with something so that the cylinders are unable to sway.
Originally Posted by Omniscient
Tell me your atleast going to deck the block after you tig in your blockgaurd Tony.
Guys running 500 whp with a good tune on stock sleeves don't worry about sleeve movement because it is so incredibly minimal. It isn't enough to crack a sleeve.
Block Guard FTW!
or say enough & sleeve the block! even better!
very good discussion
any sleeve movment is horrible. If it doesn't crack the sleeve, it will wear the head gasket down because the head isn't going to move with the sleeves and it's going to cause it to rub & eventually fail.
Block Guard FTW!
Block Guard FTW!
I want some evidence of headgasket failure without a block guard on a heavily boosted stock sleeved motor. Until then, everything I have heard from experienced engine builders says that isn't an issue.
I've heard of people doing that with concrete too. :eh: Its a good idea in theory, but I sure as hell wouldn't try anything like that in my motor.
This is for track only cars that DO NOT run for more then a few minutes at a time. Don't do this to a street car's engine or you will suffer serious cooling issues within ten minutes of starting the car.
Just so everyone knows.
