Seatbelt Chime on '06 Civic
Old Mar 16, 2006 | 02:17 PM
  #31
surfib's Avatar
surfib
Mostly passenger side seats because if you get into an accident by yourself, why waste both airbags
Old Mar 16, 2006 | 04:23 PM
  #32
Kestrel's Avatar
Kestrel
Push to shock!
Originally Posted by surfib
Pull it and see what happens, we unplugged ours at work (Ford Rangers, 05 Nissan Frontier) and the airbag light comes on... the SRS system is all connected together, and guess what.. seatbelts and airbags are a part of the SRS system.
I have pulled mine multiple times to install seats, it's just a two lead switch. Airbag light has stayed off the entire time. In fact, it's not in right now because I need to make a wiring extension to fit the Type R seats.
The weight sensor I could perhaps see being a problem, but usually the driver side has no weight sensor.
Old Mar 16, 2006 | 04:36 PM
  #33
surfib's Avatar
surfib
well two leads can do alot of things. Maybe not for the hondas but in my experience....
Old Mar 16, 2006 | 04:56 PM
  #34
Kestrel's Avatar
Kestrel
Push to shock!
Well not really.....esp if you want to integrate a weight sensor and a seatbelt sensor into one plug. Minimum of three leads then.
I digress, point is that at least with 6th gen Civics, the seat under the plug has no effect on the airbag.
Old Mar 16, 2006 | 09:57 PM
  #35
surfib's Avatar
surfib
Checked the plugs in the rangers we have at work... guess how many wires....2 and this is for the drivers side. When unplugged, throws the airbag light.... but who knows about the civic...
Old Mar 16, 2006 | 10:30 PM
  #36
ReVenGe's Avatar
ReVenGe
it woudlnt make much sense or any to have a sensor in the drivers seat..... unless they have new airbags that wait to deploy when you ass is already thrown off of it... hehe....
but just think about how the sensor works... the metal clip in the seat belt must complete the circuit or somethign like tthat..... so it cant be too hard to re-rig or something...... perhaps?
and as to the bashing which is quite common here.......... what about if hes just chillin in the parking lot with his car on listenin to music?
Old Mar 17, 2006 | 08:53 AM
  #37
sherwood's Avatar
sherwood
I missed Sean
i've seen cars hit in parking lots... and if hes basting music doubt he can har the chime
Old Mar 17, 2006 | 09:18 AM
  #38
EH339's Avatar
EH339
Originally Posted by violato
I know I **should** wear the belt...but I choose not too.. thats my choice...I should not have to hear a darn beep every 5 seconds. I just do not like wearing a seat belt....various reasons... reason does not matter... I was not looking for a course on the ethics and morality of self preservation.
How many of you that condemned me for not wearing seatbelt smoke? Each one takes a day off your life. How many of you drink alcohol? Each drink kills your brain cells. Better yet, how many of you follow this same path and walk up to smokers and educate them on the dangers of smoking??? I could go on and on....
This was a technical question regarding the ability to turn off the belt beeper... not a "tell my why I should wear my belt" plea.
The answer I guess is to go to a junk yard and buy the belt clip.
I don't smoke or drink. And no reputable garage or dealership would help you out either. What you want to do is both illegal and has serious liability issues. All I can think of is that you must have some medical problem like either being a complete dumbass or being morbidly obese for not wanting to wear your seatbelts.
Old Mar 17, 2006 | 11:16 AM
  #39
Mynard's Avatar
Mynard
Eye warship say ten!
Cut the bastards out completly and pull the fuse on them..problem solved. But you die in a small fender bender. Priceless
Old Apr 13, 2006 | 12:17 PM
  #40
punchy's Avatar
punchy
Default Disable beeper 1998 civic
Wow a bunch of wise asses on here. Too bad, it makes it impossible to find the information you are looking for with all this "you should do this, I'm not going to answer your question" bs. I found this on automotivetech.org; it worked for a 98 civic but takes some time. It will remove ANY beep from the car, seat belt, door, keys in ignition, headlights on, so beware.
Door Buzzer Removal
Remove the fuse panel nuts (2)
I think there was a screw also.
There is a gray box about 1"x3"x4" connected to the back of the fuse panel. At the bottom of this gray box is a plug with about 8 or so wires in it. Unplug this cable.
After disconnecting the gray box (ICU), there is a clip on the short sides that holds it on. Unclip this gray box. On the ICU, there is 2 clips on each of the long sides. Use a flat screwdriver to push these clips.. Try not to break them or you will have to use some black tape to hold it together later.
Once you have the ICU open, you will see there is a circuit board, and on the top right corner is a piezo tweeter. Pull the circuit board from the housing and remove the piezo tweeter using a soldering iron. (it is the round black plastic thing about 1cm in diameter by 1cm tall, with a hole in the top) If you just want the beeper to be quieter, I suggest a little piece of tape over the hole. I chose to remove it altogether.
Put the whole thing back together and plug the ICU back into the fuse panel and reconnect the wire to the ICU.
Now your hazards and wipers should still work, however you will not have that annoying beeper any longer.
This fix took about 25 minutes but I had to figure out how it all came apart.
from http://www.4thgenerationcivic.com/
