Supercharger Or Turbo??? For D16y8
Originally Posted by Omniscient
Tey all convert to the b-side after a while.
h:
h:
Originally Posted by 2gr84u
there is NOTHING you can do a honda automatic tranny to make handle MORE power then a manual transmission, and if there is the cost of such a modifcation would be so absurd you would have to be a moron not to just switch to a more efficient 5 speed set up. You can only help a automatic SURVIVE boost, where a manual transmission can be made to CONTROL boost. The advantage comes with the massive amount of aftermarket clutch options, every where from slightly better then stock to bullet proof.
I dont get why so many people with automatics cant get over the fact that its not designed for anything but to put a car from point a to point b in the easiest possible way.
http://www.jegs.com/webapp/wcs/store...d=89511&CT=999
Even with a supercharged single cam the torque will still be weak.
Originally Posted by Driverman5777
PUT A B-SERIES IN IT!!!! yous wasting money even if your "different" you will not be making as much horsepower.
this thread makes my head hurt.........the irrelavence of turbo vs supercharger is retarded....your auto tranny is the set back.....either way you are gonna blow it to shit...and the money you would spend make your A/T worth a shit isnt worth it...done.
Personally If i was in the market for adding some power to a d-series motor I would personally go with a super charger. ( i currently have a turbo on my b18c) and the reason for it is simple.
Most of the time people who are wanting to add a little speed to thier d series arent going to be willing to back it financially to properly turbo it. a super charger is a nice cheap and fairly reliable way to get some safe power out of the motor without killing it.
sure the cost of a jrsc or similar is abot the same as a standard turbo "kit" on the market but anyone who really knows... a turbo "kit" isnt a complete FI solution. atleast for doing it right. If you have and are willing to put the funds into the motor to properly turbo it then you should seriously consider a swap in order to really maximize the gains with a dohc motor. either way this is just my opinion and youre free to do what you like but atleast it gives you something to look at.
ok buy that, and ill spend the same amount a stage 3 clutch. Lets see which one holds more power and puts it to the wheels most effectivly
