Supercharger Or Turbo??? For D16y8
Old Mar 7, 2006 | 08:58 PM
Originally Posted by InfiniteVTec
B18C1... GSR style... or jack a type R from an unsuspected person and make it an all motor monster ;x
thanks FUCKED UP
Originally Posted by Driverman5777
Swap in a B18b w/ a GSR tranny then turbo it.
I agree...h:
Old Mar 8, 2006 | 06:38 AM
2gr84u's Avatar
2gr84u
2gr84u
Get The Auto Tranny Kit From Tci And You Handle More Power Than A M/t
there is NOTHING you can do a honda automatic tranny to make handle MORE power then a manual transmission, and if there is the cost of such a modifcation would be so absurd you would have to be a moron not to just switch to a more efficient 5 speed set up. You can only help a automatic SURVIVE boost, where a manual transmission can be made to CONTROL boost. The advantage comes with the massive amount of aftermarket clutch options, every where from slightly better then stock to bullet proof.
I dont get why so many people with automatics cant get over the fact that its not designed for anything but to put a car from point a to point b in the easiest possible way.
Old Mar 8, 2006 | 08:56 AM
raiden571's Avatar
raiden571
turning u inside out
u should be hung and quartered
Old Mar 8, 2006 | 09:16 AM
eonsx311's Avatar
eonsx311
today is not my birthday.
Originally Posted by taliano23
I want to know whats better a supercharger or a turbo kit?? Also, can i find a turbo kit for under 2000.00? What site??? its for a d16y8. I have an automatic transmission.
help me out guys!!
Turbo, and dont buy a kit. Just build one.... go here www.homemadeturbo.com REEEAAAADDDDDD. you will learn tons. im in the process of starting my turbo build right now and hmt is an awesome source.
Old Mar 8, 2006 | 02:07 PM
hoyoung02's Avatar
hoyoung02
HEAT:Shift_TechkaV
your auto tranny[i like to call all honda automatic trannys slush box] will start slipping due to the power it will be handling after you go boost.
you can upgrade your automatic transmission if you really REALLY want to keep the auto, but what is the point in that when you can just get a manual for the price of upgrading the automatic?
Old Mar 8, 2006 | 04:15 PM
southernimage's Avatar
southernimage
supercharger will give you more low end torque which is one thing our little sohc's lack but it takes a lot more gas than a turbo because it is always boosting. What i recommend though is to build the everliving crap out of that motor and put a turbo on, but please make sure you have your air and fuel tuned properly so you dont get detonation in the cylinder.
Old Mar 8, 2006 | 04:25 PM
Omniscient's Avatar
Omniscient
warm butter on toast
Even with a supercharged single cam the torque will still be weak.
Old Mar 8, 2006 | 04:29 PM
Driverman5777's Avatar
Driverman5777
PUT A B-SERIES IN IT!!!! yous wasting money even if your "different" you will not be making as much horsepower.
Old Mar 8, 2006 | 04:31 PM
Omniscient's Avatar
Omniscient
Tey all convert to the b-side after a while.h:
Old Mar 8, 2006 | 05:01 PM
2gr84u's Avatar
2gr84u
2gr84u
with the properly sized turbo you can add as much torque to the low end as you can with a supercharger. You really dont need to build the hell out of the motor just to boost it, your good to about 230hp on stock guts so long as compression test and leak down testing are looking good.
There is one HUGE advanatage to boosting a SOHC motor, and that is COST. If you blow one up, there is another 300-600 bucks away, cant say that for any B series motor. Also, a turbo D done right will destroy alot of B series swaps alone, and are capable of making very comparable numbers to even high boost b series motors after some internal work and good turbo sizing. SO swaping the motor isnt the best bet answer to everything
