94 civic airbag removal help
Old Feb 23, 2006 | 09:11 PM
darkcyde's Avatar
darkcyde
Default 94 civic airbag removal help
i'm looking to remove both the driver and passenger airbag from my 94 civic ex coupe.
does anyone have experience on how to properly remove them? im really not looking to break my nose having them go off, so any help with this is greatly appreciated!! thanks
Old Feb 23, 2006 | 11:31 PM
Kestrel's Avatar
Kestrel
Push to shock!
I've worked on EK ones, but I imagine EG's are fairly similar. You disconnect positive and negative terminals on your battery. Wait at least 3 minutes for all the electronics to run out of power. There's a cover on the bottom part of the steering wheel. Pull the cover off, there's a big yellow plug. Disconnect it short it out (my EK has automatic shorting plugs, I think older EK's, and probably EG's, had a red short plug you plugged into the airbag). And then you can take it out. It's pretty much the same procedure for the passenger side bag, but the plugs are under the dash.
Old Feb 24, 2006 | 06:22 AM
darkcyde's Avatar
darkcyde
i knew you had to unplug the battery, but i had also heard about removing the fuse for them (if their is one), does that sound framilar? anyone have any further advice for this removal? i just want to make sure for a FACT that they're dissabled so it doesnt deploy on me!! thanks for the help
Old Feb 24, 2006 | 09:47 AM
Kestrel's Avatar
Kestrel
Push to shock!
You can remove the fuses too. The Honda service manual doesn't mention it, but it couldn't hurt. The biggest thing is unplugging the battery, and shorting the plug once the airbag is unplugged. I think the biggest risk removing the airbag is accidentally static shocking the airbag plug.
Edit: And waiting the 3 minutes. That was noted in bold in the service manual.
Old Feb 24, 2006 | 11:49 AM
hondakid's Avatar
hondakid
where a helmet and hope for the best =)
Old Feb 24, 2006 | 09:58 PM
darkcyde's Avatar
darkcyde
do you know exactly which fuses to pull? thanks for the help guys!
Old Feb 25, 2006 | 12:49 AM
Kestrel's Avatar
Kestrel
Push to shock!
I have no idea. But disconnecting the battery basically does the same thing.
Old Jun 2, 2006 | 08:56 AM
bandit1911's Avatar
bandit1911
How do you short the plugs? I have a 95 Civic and need to replace the bag also.
Old Jun 2, 2006 | 09:18 AM
flyromeo3's Avatar
flyromeo3
Why would you want to remove a SAFETY device?
I know because if the air bag didnt go off in my friends car my ass would of been tossed out the windshield.
I think a broken nose is far better than being killed.
Old Jun 2, 2006 | 09:25 AM
Kestrel's Avatar
Kestrel
Push to shock!
Well I removed it so that I could install the S2000 one h:
