Letter from Honda
Old Feb 13, 2006 | 11:45 PM
Kai's Avatar
Kai
Rotorphile.
Originally Posted by sibiryk
Screwdriver>odometer>-11:rick:
Junkyard cluster + your car
= win!
(or) = serious fraud charges!
Old Feb 14, 2006 | 08:21 AM
alanMI88's Avatar
alanMI88
I got that same letter yesterday, I only have 103k! I'm looking forward to free parts! I says they'll fix any emmission related parts, I have a rusted cat and header resulting in an exhaust leak. I hope they'll fix that!
Old Feb 14, 2006 | 11:18 AM
jokercard's Avatar
jokercard
hey guys, i just called them. this is what i found out:
-if you paid for repairs, as i did when i bought the car to get it smogged i had to buy a new cat which was $600+, send them a bill of what was done and prof of method of payment.
-you can fax or mail it to them fax#(909)664-9009
-downside it will take 4-6 weeks for processing.
hope this helps.
c-ya
Old Feb 14, 2006 | 11:38 AM
Running925's Avatar
Running925
Your Powder Coater
doubt they will give me a free tune-up when they see a b-series & 2.75inch exhaust from turbo back with no cat on my car
haha
Old Feb 14, 2006 | 11:47 AM
kidd_honda's Avatar
kidd_honda
i think it only applies in California.
Old Feb 14, 2006 | 11:52 AM
Running925's Avatar
Running925
Your Powder Coater
that kinda stinks!
Old Feb 14, 2006 | 01:10 PM
alanMI88's Avatar
alanMI88
If it only applies in california, why whould they send me the letter in michigan?
Edit: I just re-read the letter. It says nothing in the letter about having to be in California! It said only emissions-related parts are covered, and for a complete list of warranted parts refer to the warranty book. I downloaded the warranty book from www.hondacars.com. Under the emissions section the following parts were listed for emissions warranty:
• Evaporative emission control canister.
• Evaporative emission purge control diaphragm valve.
• Evaporative emission purge control check & relief valve.
• Evaporative emission purge control vacuum switching valve.
• Fuel tank.
• Fuel fill pipe and cap.
• Fuel fill neck restrictor.
• Fuel tank rollover & float valve.
• Fuel tank evaporative emission valve.
• Evaporative emission purge control solenoid valve.
• Evaporative emission two-way valve.
• EGR vacuum control valve.
• EGR control solenoid valve.
• EGR valve.
• EGR valve lift sensor.
• Common chamber & orifice.
• EGR backpressure transducer.
• EGR thermal vacuum valve.
• EGR vacuum switching valve.
• Three-way catalytic converter.
• Warm-up three way catalytic converter.
• Left exhaust manifold.
• Right exhaust manifold.
• TDC sensor.
• Crankshaft position sensor
• Cylinder position sensor.
• Distributor ignition housing.
• Distributor ignition cap and rotor.
• Distributor.
• Ignition coils.
• Ignition control module.
• Ignition timing adjuster.
• Ignition wires.
• Power switch.
• Spark plugs
• Engine Control Module (ECM).
• Fuel injectors.
• Fuel rail.
• MAP sensor.
• Heated oxygen sensors.
• Oxygen sensors.
• Barometric pressure sensor.
• Intake air temperature sensor.
• Throttle position sensor.
• Engine coolant temperature sensor.
• Knock sensors.
• Powertrain control module.
• Transmission control module.
• Countershaft speed sensor.
• Vehicle speed sensor.
• Fuel pressure regulator.
• Fuel pressure regulator vacuum switching valve.
• Idle air control valve (IACV).
• A/T gear position switch.
• Lock-up clutch control solenoid valve.
• Shift control solenoid valve. Fuel filter
• Air cleaner element, housing, and cover
• Air flow sensor.
• Air regulator.
• Common chamber.
• Throttle body assembly.
• Throttle switch.
• Intake manifold.
• Pulse secondary air injection control solenoid valve.
• Pulse secondary air injection valve.
• Secondary air injection check valve.
• Secondary air injection management valve.
• Secondary air injection manifold.
• Secondary air injection pump.
Old Feb 14, 2006 | 04:20 PM
96Civic_Coupe's Avatar
96Civic_Coupe
Assistant to the manager
so its available everywhere? MA ?
Old Feb 14, 2006 | 04:22 PM
remy's Avatar
remy
Didnt u read what alanMI88 just said.that he lives in Michigan and he received a letter.It is a nationwide thing,not just one single state!!!!!
Old Feb 14, 2006 | 04:23 PM
96Civic_Coupe
wooot!!!
