need some help *pics*
Old Feb 2, 2006 | 11:53 AM
bambbrose's Avatar
bambbrose
Originally Posted by 97civicEXVTEC
so your saying put pressure on the shaft or on the brown part (sorry not up to terms) ? how much pressure should i be putting on them? thanks
grab the ends, out by your hubs and push into the trans til it compresses all the way. However much pressure it takes to compress them. then have a friend tap the end of hte spindle with a sledge or any hammer that has weight behind it. also try twisting it if it doesn't go in still.
If you still can't get them to go in pull them back out and make sure your c clip isn't bent
Old Feb 2, 2006 | 12:10 PM
crzy000's Avatar
crzy000
the way I put mine in is that I pull the axle about 1/2 out and push it in with a little force. and if it don't go in I'll do the same way again but make sure to rotate or turn the axle about 1/2 clock wise. it always work for me. BUT MAKE SURE THAT YOUR CAR IS NOT ON GEAR..
Old Feb 2, 2006 | 02:24 PM
97civicEXVTEC's Avatar
97civicEXVTEC
alright the hammer tapping worked. w00t :yay:. now all i have to do is bleed the clutch line and then ill let you know how it went.
Old Feb 2, 2006 | 02:42 PM
bambbrose's Avatar
bambbrose
glad to hear it worked out for you.
Old Feb 2, 2006 | 03:34 PM
97civicEXVTEC
thanks a lot man an thanks for your help. only one more problem.. when i pump the clutch all that comes out of the bleeder valve is air and occasionally a spritz of clutch fluid. can there be that much air in my lines?
Old Feb 2, 2006 | 05:36 PM
bambbrose's Avatar
bambbrose
do you have a little hose on the nipple of the bleeder? do that and then put the hose into a bottle of brake fluid... this won't allow the clutch to suck air back in every time you let the pedal back up
Old Feb 2, 2006 | 05:44 PM
97civicEXVTEC
:doh: i was going by westcoaststyles write up and it showed a pic of that but i never thought about air being sucked back up. alright ill do that tommorow. thanks again
