b16 from 00 si into 94 cx
Old Jan 28, 2006 | 09:28 AM
qtiger's Avatar
qtiger
Originally Posted by b20hatchy
you need a gsr harness. You also need ob1 dizzy, alt, injectors.
Wrong. The correct GSR harness will be OBD2 and thus connect properly to all the obd2 equipment.
Originally Posted by waaBAAH
way to much work to run an obd2 harness. an obd 2 harness is a one pice design so you would need to run everything into the firewall. would be a lot easier just to get obd 1 parts......like you said you have....and just get a gsr harness. plug and play from that point. might need to longte a wire or two but for the most part...it is simple
WTF? Here's a tip: GSRs were OBD2 as well. They have a seperate engine harness. Look, you're wrong, stop scraping for silly reasons why he has to use obd1 stuff, because he doesn't. The only reason you have to swap to OBD1 dizzy, alternator, and injectors is if you are using the car's original OBD1 harness. Even then it's possible to swap OBD2 injector clips, and rewire for the distributor and alternator.
Old Jan 28, 2006 | 04:21 PM
Civic2Scooby's Avatar
Civic2Scooby
so the OBD2 harness will plug right into the obd1 ECU harness and you can then run the obd-1 ecu?
and by the way, why did it come with a p28..that isnt the ecu a stock b16a2 runs on.
Old Jan 28, 2006 | 06:01 PM
ReVenGe's Avatar
ReVenGe
well theguy built the motor.... so its got some goodies on it...... and one of em is a p28 ecu chipped by chrome
Old Jan 28, 2006 | 06:54 PM
qtiger's Avatar
qtiger
Yes. The "extra" OBD2 bullshit is all on a fourth plug that connects to the rest of the car on the passenger side shock tower. On an OBD1 car, just leave that plug hanging and you're good to go.
Old Jan 28, 2006 | 08:34 PM
ReVenGe's Avatar
ReVenGe
sweet.
so let me review...
my car is obd1
the new engine is obd2
ok ok..... so lets see if i can go through this... obd2 engine--> obd2 harness--> into OLD obd1 chasis harness --> into new obd2 computer.?
Old Jan 29, 2006 | 08:16 AM
Civic2Scooby
no shit...well thats good to know...you learn something new everyday :goodjob:
Old Jan 29, 2006 | 01:51 PM
qtiger's Avatar
qtiger
You could run an obd2 computer but it's cheaper and easier to use obd1. The plugs on the ECU are different obd1/obd2 and you'd need to use an adapted to get an an obd2 comp. Just use an obd1 ecu, it'll never know the difference.
Old Jan 29, 2006 | 02:20 PM
ReVenGe's Avatar
ReVenGe
so i shouldnt use the chiped p28 ecu that comes with the engine?
Old Jan 29, 2006 | 02:33 PM
waaBAAH's Avatar
waaBAAH
p28 is obd1...that is fine and will plug in
Old Jan 29, 2006 | 03:23 PM
ReVenGe's Avatar
ReVenGe
ok..... so i got 2 different things going on.......
so i've gather the p28 is acutaly obd1 like my car is so that will plug into my chasis harnes no problem.
and even tough the engine and the engine harness is obd2 i dont need a conversion kit because i can just leave what ever extra plug i have unplugged and the rest can go into the obd1 chasis harness?
i gues the thing i was confused about was the chasis harness. and the adapter harness's that i can buy..and if i needed one
