Stroker kit???
Old Jan 7, 2006 | 09:03 AM
loafeidb's Avatar
loafeidb
Default Stroker kit???
what exactly is a "Stroker kit"?? and is it possible to turbo an motor with a stroker kit ,and also is it worth it?? I dont know much when it comes to that ,
Old Jan 7, 2006 | 09:09 AM
JoePoonani's Avatar
JoePoonani
Lexus Tech y0!!
a stroker kit basically increases the displacement of the motor. im not too sure though.
Old Jan 7, 2006 | 09:45 AM
jeterkm02's Avatar
jeterkm02
hatchbacks r my anti-drug
Yes, but more so... A stroker kit increases the circular diameter at which the crankshaft spins at. The increase in diameter provides more low end leverage (torque) at the expense of crankshaft speed.
to help understand this... picture a 6" ratchet and a 2' breaker bar. The breaker bar (equivalent to the stroked crankshaft), will provide more torque since it allows for less work to be done in a greater distance span. On the other hand the 6" ratchet (not-stroked crankshaft) provides much less torque since a greater amount of work has to be done in a smaller distance span.
Old Jan 7, 2006 | 06:06 PM
loafeidb's Avatar
loafeidb
so that basically stops the motor from revving high???
Old Jan 7, 2006 | 06:30 PM
InfiniteVTec's Avatar
InfiniteVTec
The Dealer
less revs needed to make the same power.
Old Jan 8, 2006 | 03:08 PM
loafeidb's Avatar
loafeidb
but then you can still rev as high as normal and thus putting down more power??
Old Jan 8, 2006 | 03:16 PM
hobozcar's Avatar
hobozcar
Give Me Your Tots!
honda motors are made to rev high. stroker kits are not going to do what you expect them to for the money you are going to pay for it. just build, turbo, and tune.
Old Jan 8, 2006 | 03:21 PM
loafeidb's Avatar
loafeidb
see thats what i love about honda motors!!! but my friend (a real mitsu person) said that a honda motor will never have more hp than the evo motor, so i was just trying to find out how many different ways thats possible
Old Jan 8, 2006 | 04:29 PM
97civicEXVTEC's Avatar
97civicEXVTEC
one way.. boost
Old Jan 8, 2006 | 04:43 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
Yeah, he is right. The Evo starts with a hell of a lot more, so if you go mod for mod, the Evo will always make more power.
