Engine swap, two problems
Just recently swapped out my D15B7 in for the JDM D16A VTEC. Overall the swap went pretty smooth, one motor mount was different, and she's now throwin a code 19 (Automatic Transmission Lock Up Control Solenoid Valve). The funny thing is I have the manual 5 speed bolted up to the engine. Is it possible that I was given an automatic ecu with this swap? Also at idle, she will rev between 800 and 1200 rpms when warm. Any input will help me out.
BTW,
The D16A is very impressive compared to what I had. When VTEC engages, I can hear and feel the difference. Very good buy if someone is interested in upgrading their non-VTEC car.
BTW,
May sound stupid on my part, but was your car always a manual? It sounds like you have a matic ecu if it's throwing a matic code. And what do you mean by revs between 800 and 1200, is it like an eradic jumping? That's a common problem.
It was always a manual. The new engine has the original tranny bolted on. To be more specific, when she's cold and starts up and begins to warm, the engine will start to rev UP AND DOWN between 1000 and 1400 rpms or so. It will continue to rev up and down until it warms up a tad more, where it seems to idle just fine at about 800 rpm. After driving for a bit, and coming to a stop light or sign, it will rev up and down again between 800 and 1200 or so rpm. At first I thought maybe it was just the idle air control valve, but with it throwing a code 19, I kinda figured that maybe I was sold an automatic ecu, which by the way is a P91.
Originally Posted by JoePannone
is it a D16 or a B16. there were no D16A vtec engines ever made.
p91 is sohc 1.6 obd1 92-95 http://www.pgmfi.org/twiki/bin/view/Library/P91
https://www.honda-acura.net/forums/s...d.php?t=134197
sure it answers part of your question......you thought maybe you had a auto ecu. im searching for more answers for you....unless you thnk that i am not helping you...then i will stop. your call
