Strange Engine Problems.. any ideas? :) PIX
Old Dec 13, 2005 | 10:41 PM
B18 Black Widow's Avatar
B18 Black Widow
did you send the camshafts in to the machine shop too? if so hod they check out if not you could check thea and yea does sound like thevalve cover gromets.id do what jdm said but i dont know could a camshaft do that?
Old Dec 14, 2005 | 08:15 AM
Running925's Avatar
Running925
Your Powder Coater
cam shafts could do that if they were worn down but they arn't, they both look good.
found 2 vacume leaks & solved them.. i'm changin plugs & sealin up the cover to go for a ride & test.. i'll let u guys know what she does.
Old Dec 14, 2005 | 10:04 AM
Civic2Scooby's Avatar
Civic2Scooby
thats a damn long test drive :fawk:
Old Dec 14, 2005 | 10:31 AM
bambbrose's Avatar
bambbrose
also tps and map sensors can cause bucking. If you have a spare TB you could try and change it out if the problem persists
Old Dec 14, 2005 | 05:55 PM
Running925's Avatar
Running925
Your Powder Coater
i might try that just for the hell of it.. but it's not throwing a code for the tps or the map sensor.
i tested the tps & it tested fine voltage wise...
sry i didn't return to the forums immeadiatly! :fawk:
Old Dec 16, 2005 | 05:44 AM
jdmeg6hatchy's Avatar
jdmeg6hatchy
i
is everything going ok for this now?
Old Dec 16, 2005 | 11:27 AM
Running925's Avatar
Running925
Your Powder Coater
yep.. all problems resolved..
consisted of so many little things i can't even remember them all.
main probs found in leaky ness / & distributor
thanks for all the help everyone.
