sohc v build...
Old Sep 28, 2005 | 09:34 PM
mini-me civic's Avatar
mini-me civic
Default sohc v build...
im thinking of building a sohc v.. i want to do internals so that i can run a turbo.. i wanna atleast run 10-12 lbs of boost.. i was wonderin if n e one knows of a perfect set up from pistons, valves, springs, etc..one that is good and affordable..
Old Sep 29, 2005 | 12:31 AM
Dark_kiseki's Avatar
Dark_kiseki
I even posted this myself just go click the search button and type what you want it happens to be a very useful tool as you guys have taught me. So go use it.
Old Sep 29, 2005 | 01:37 AM
dE.fUsEd's Avatar
dE.fUsEd
I still like honda's. :-/
Skunk2 has titanium retainers, steel valves, and hi performance valve springs for around $700-$800, depending where you shop. Might find them cheaper on ebay or something too.
Old Sep 29, 2005 | 11:15 AM
1995Civic's Avatar
1995Civic
I hate ricers
IMO i would go with Crower valvesprings/TI retainers, Zex 59300 Cam, Zex cam gear (AEM, Skunk2, etc) Ferrea oversized valves (if you want valves?) P&P, JG Intake Mani.
For the Block, although you dont need upgraded internals for 10-12psi, you are being smart and doing it anyway. I like that. CP Pistons/Pauter or Manley Rods (Eagle H-beams would be good too) With that, you should definitely be set for high boost. As for Fuel Management, I would run a P28 ECU chipped w/ uberdata, Walbro 255 fuel pump, RC Injectors (440-550cc), and possibly a FPR and Fuel Rail. Then, anything else you want besides that. Make sure you do the proper things before boosting. Compression and leakdown tests, and replace your Timing belt (if needed), Oil and water pump, and run NGK spark plugs 2 steps colder! BRK7E11's i believe? good luck dude
Old Sep 29, 2005 | 06:39 PM
raiden571's Avatar
raiden571
turning u inside out
AHHHHHHHHHH!!!! IT BURNS
https://www.honda-acura.net/forums/s...d.php?t=206354
Old Sep 29, 2005 | 06:54 PM
InfiniteVTec's Avatar
InfiniteVTec
The Dealer
If you were working with a D16Y8.
try
Zex Cam 59300
Zex's Valve Spring and Retainer Kit that's made for its cam
Ferrea Competition Race Valves
SRP 9:1 Pistons
Eagle H-Rods
BlockGuard (just for an added insurance policy)
Darton Sleeves (If you plan on boosting over 12psi later on)
B&M FPR
Walbro 255 FP
AEM EMS
550RC Injectors
STR Fuel Rail
Denso Irridium Spark Plugs, go 2 steps colder
I believe that would be a sweet setup. If I could do that I would, but I'm stuck boosting an Auto D16... and no one seems to make engine management systems for autos... I'd personally would go with the AEM EMS, you don't need convert to OBDI to run it.
Old Sep 29, 2005 | 07:26 PM
1995Civic's Avatar
1995Civic
I hate ricers
try
Zex Cam 59300
SRP 9:1 Pistons
Eagle H-Rods
B&M FPR
Walbro 255 FP
AEM EMS
550RC Injectors
STR Fuel Rail
Didnt i just list pretty much the same setup, other than the EMS?
Old Sep 30, 2005 | 03:58 AM
InfiniteVTec
The Dealer
yeah kinda, great minds think alike
Old Sep 30, 2005 | 07:30 AM
1995Civic's Avatar
1995Civic
I hate ricers
tru that homie!
