shifter problem
Old Sep 13, 2005 | 08:03 PM
alanMI88's Avatar
alanMI88
Default shifter problem
if you have looked through any previous posts, u'd see that I have had a problem with my shifter. first i explained the problem, i was told i needed a new shift bushing. next i posted asking how to do that. i found out, so i bought new energy suspension shift bushings and last weekend i installed them. the thing is, the shifter feels exactly the same, and i still have the same problem. when its in gear, any gear the shifter lever is really loose. it can move side to side like 2 - 3 inches. there are no loose bolts in the linkage, i checked that. and i just changed the bushings. so now what?
Old Sep 13, 2005 | 08:04 PM
Paul's Avatar
Paul
Eater of Rice
probably the shift fork inside the transmission. you'll need to pull the transmission and have it looked at.
Old Sep 13, 2005 | 08:11 PM
jdmeg6hatchy's Avatar
jdmeg6hatchy
i
at the bottom of the shifter is it a set of bearings or a cylinder spacer???
Old Sep 13, 2005 | 08:12 PM
alanMI88's Avatar
alanMI88
that sounds kinda serious. is there mybe another bushing i would need. the bushings i got went at the trans end and then a stabilizer. there werent any for were the shift rod meets the other rod under the car. that area seemed kinda loose. could that be the problem. if it is, where would i get a bushing for that?
Old Sep 13, 2005 | 08:15 PM
alanMI88's Avatar
alanMI88
i noticed there were 3 little black rubber band looking things in there, but one was missing, there should have been four, but they were so small, i figured that couldn't be causing the problem. it could be part but not the whole thing.
jdmeg6hatchy
i
it is the problem. i had the same prob. i can help. are you using a short shifter? if so what kind? are there bearings at the bottom of the shifter lever???
Old Sep 13, 2005 | 08:17 PM
alanMI88's Avatar
alanMI88
nope this is just stock
Old Sep 13, 2005 | 08:20 PM
alanMI88's Avatar
alanMI88
if i remember at the bottom of the shifter, there was a hollow circle. in it was a cylinder with three black rubber washer looking things, it looked like one was missing
i should have taken pics
i can do that weekend if need be
Old Sep 13, 2005 | 08:22 PM
jdmeg6hatchy
i
huh. i dont know why your stock one would be effin up??? hmmm...
Old Sep 14, 2005 | 01:18 PM
alanMI88's Avatar
alanMI88
anyone have any other thoughts? i wanna get this fixed
