shifter problem
Old Sep 15, 2005 | 01:11 PM
alanMI88's Avatar
alanMI88
Old Sep 15, 2005 | 01:41 PM
Jafro's Avatar
Jafro
I'm made of meat!
Replace the dowel pin where the shift linkage attaches to the transmission. There IS a "bolt" or better known as a dowel pin that connects the shifter rod to the transmission. If it wears or moves out of place, then it will feel REALLY loose side-side. It's under the car, right in the middle, and at the back of the transmission. The part is $7 at the Honda dealer, and you'll laugh when you see the part.
There's supposed to be a round band/clip kind of thing that goes around the dowell pin to cover it up and keep it from falling out, but many mechanics "forget" to put it back on there after doing a clutch job. Maybe that's missing and it's falling out, or maybe someone used the wrong $#!† to put it back together.
EDIT: Get someone to move the shifter back and forth while it's in gear and see if you see it slipping at that point that I just described. Don't bother with jackstands or anything, just park over a ditch or something so you can get to it easily or crawl up under it while it's not running.
Old Sep 15, 2005 | 02:26 PM
Omniscient's Avatar
Omniscient
warm butter on toast
Oh no not the bitch pin. Took me a good two days of tryign and still couldn't get it so I just pulled my old engine out with the linkage still attached to the tranny.
Old Sep 15, 2005 | 02:37 PM
jdmeg6hatchy's Avatar
jdmeg6hatchy
i
haha. ill probably have to do the same thing.
Old Sep 15, 2005 | 05:18 PM
alanMI88's Avatar
alanMI88
is this one of the bolts i had to take out when i chnged the bushings?
Old Sep 15, 2005 | 05:38 PM
lowbrow's Avatar
lowbrow
12:00AM Atlanta time...
Mine was the exact same way, and it was where "the shift rod meets the other rod under the car" replaced that bushing, and it became very tight.
Old Sep 15, 2005 | 07:16 PM
alanMI88's Avatar
alanMI88
where did u get that bushing? i payed $20 for the energy suspension bushing set, and that didnt have the right bushing. where did u get urs? thanks
Old Sep 16, 2005 | 07:03 AM
Jafro's Avatar
Jafro
I'm made of meat!
YES. THE BITCH PIN.
https://www.honda-acura.net/forums/s...d.php?t=133142
https://www.honda-acura.net/forums/s...d.php?t=127053
Or do a search for "dowel pin"
Old Sep 16, 2005 | 07:04 AM
Jafro's Avatar
Jafro
I'm made of meat!
It's not a bushing causing your trouble.
Old Sep 16, 2005 | 02:10 PM
alanMI88's Avatar
alanMI88
where exactly is this pin located? i dont really understand where it located
