camber kit help
I am about to put a tein ss coilover set on my '98 civic, but I really am not sure what to get in the way of a camber kit. If anyone has any info about brands or kits it would be greatly appreciated!
-Z
-Z
i have the 1st gen skunk2 front upper A arm and the SRR rear camber kits. both have worked very well for me with no problems of slipping or failure. like civicracr said, i would be more concern of ur toe corrections as it tends to eat the tires out faster then camber wear. but i would highly recommend the skunk2 front A arm and for the rear, u can go cheap with longer bolts and washers or get a full dog bone replacement camber kit that has adjustability such as ingalls and srr.
Get the car aligned, spec on most hondas is out to -1.5, so your car may still be in spec and not need a camber kit. Camber does not eat tires, Toe is what kills tires fast, camber will cause the tires to wear unevently but it is a slow process and generally does not shorten the life of the tire.
You need a camber kit if you're going to be lowering it at all, in my opinion. I like things to be done right, and if you had seen the tires I just took off that were victim of this car's previous owner's lowering job, you'd know why.
On the inside edge, the tires are literally down to the steel belting after _maybe_ a year total of casual use. I have other tires I put on in the winter, too.
I'm sure he didn't.
However, it was only on the inside edge that it was worn down.
